Outer roof trim split !
by markse495 » Mon Jan 14, 2013 4:19 pm
Hi just getting over the excitement of my restored girl, :dance: yet another prob and its this (scuse back of me head believe me looks better than the front :lol: Think a year or so ago some turnip!! TRIED TO BREAK IN :twisted:
any ideas on a fix guys?? :(
Mse495.
markse495
Re: Outer roof trim split !
by craigyboy » Mon Jan 14, 2013 6:07 pm
You have to take out the rubber seal at the top of the doors
and back windows.Which involves taking out the inside panels
by markse495 » Mon Jan 14, 2013 7:27 pm
Sounds a bit of a job then!
Mse495/ :(
markse495
by craigyboy » Mon Jan 14, 2013 8:29 pm
It only takes a couple of hours mate,I had to do it
a few months ago
by v6 steve » Mon Jan 14, 2013 9:16 pm
it is a bit of a pain but youll get it done in a morning
by MadOnVaux! » Tue Jan 15, 2013 5:25 pm
You'll also need tin snips to cut slots in the metal where the rear windows bolt through.
by craigyboy » Tue Jan 15, 2013 5:55 pm
MadOnVaux! wrote:You'll also need tin snips to cut slots in the metal where the rear windows bolt through.
Never needed tin snips when I done the job mate
by markse495 » Tue Jan 15, 2013 6:20 pm
For now i may use electrical black tape, another guy used this and he said it works as long as its done very neatly, using a special strong glue to bond it :o
Msed495.
markse495
by MadOnVaux! » Tue Jan 15, 2013 6:51 pm
How did you get the rear windows out then?
as they dont come out until that trim is removed and you cant get to the screws to get the trim off until the rear window is out??
by craigyboy » Tue Jan 15, 2013 7:22 pm
loosen all the plastic nuts from the window then push it out this
gives you access to the metal trim then you can unscrew it
by v6 steve » Tue Jan 15, 2013 9:11 pm
you can get it out with out cutting the holes but if you cut slots it makes putting the window back in so much easer now that the trims have gone hard
