help needed with my v6 please
Re: help needed with my v6 please
by Allys Cally » Mon Apr 04, 2011 9:30 pm
did you change the plugs as well as the coil pack and leads?
by rich30mex » Mon Apr 04, 2011 9:32 pm
no the plug got took out and cleaned there not that old and looked like new
by Allys Cally » Mon Apr 04, 2011 9:35 pm
doesnt mean to say theyre not at fault though.
by v6 steve » Mon Apr 04, 2011 10:41 pm
have you checked your timming
by rich30mex » Fri Apr 08, 2011 7:44 pm
just done the timing it looks spot on to me so up to press iv done
compression thats at 15-16 bar on all 6 cylinders
cam sensor (off vectra)
crank sensor (off omega)
checked all the air flow pipes for cracks and leaks
second hand coil pack and leads
any more ideas cos this is doing my head in realy bad now
1st to help me solve it gets a drink ov your choice off me lol
by spoon » Sat Apr 09, 2011 12:27 pm
could be the ICV, Had similar issues, replaced it and no more bother, i went down the ignition amp route and cam angle sensor as i had code 93, turned out to be the ICV, random i know...
spoon
by rich30mex » Sat Apr 09, 2011 2:09 pm
spoon wrote:could be the ICV, Had similar issues, replaced it and no more bother, i went down the ignition amp route and cam angle sensor as i had code 93, turned out to be the ICV, random i know...
whats the ICV mate ???????
by v6 steve » Sat Apr 09, 2011 6:36 pm
idle control valve
by rich30mex » Sat Apr 09, 2011 6:49 pm
were abouts is the idle controle valve loctaion mate
by v6 steve » Sat Apr 09, 2011 6:51 pm
i think its the round tube like thing under the throttle body
by rich30mex » Sat Apr 09, 2011 7:16 pm
thanks
by MarkV6 » Sat Apr 09, 2011 8:48 pm
rich30mex wrote:were abouts is the idle controle valve loctaion mate
This might be of help
Hotlinked/stolen from here: http://www.v6calibra.net/
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
by Fraz » Sun Apr 10, 2011 12:02 am
have you changed the ignition amplifier???
by rich30mex » Sun Apr 10, 2011 4:54 pm
Fraz wrote:have you changed the ignition amplifier???
were is it located please
by MarkV6 » Sun Apr 10, 2011 5:13 pm
It's here, just under the PAS reservoir bolted to the nearside chassis leg
I now own this one.
