help needed with my v6 please
Re: help needed with my v6 please
did you change the plugs as well as the coil pack and leads?
no the plug got took out and cleaned there not that old and looked like new
doesnt mean to say theyre not at fault though.
have you checked your timming
just done the timing it looks spot on to me so up to press iv done
compression thats at 15-16 bar on all 6 cylinders
cam sensor (off vectra)
crank sensor (off omega)
checked all the air flow pipes for cracks and leaks
second hand coil pack and leads
any more ideas cos this is doing my head in realy bad now
1st to help me solve it gets a drink ov your choice off me lol
could be the ICV, Had similar issues, replaced it and no more bother, i went down the ignition amp route and cam angle sensor as i had code 93, turned out to be the ICV, random i know...
spoon
spoon wrote:could be the ICV, Had similar issues, replaced it and no more bother, i went down the ignition amp route and cam angle sensor as i had code 93, turned out to be the ICV, random i know...
whats the ICV mate ???????
idle control valve
were abouts is the idle controle valve loctaion mate
i think its the round tube like thing under the throttle body
thanks
rich30mex wrote:were abouts is the idle controle valve loctaion mate
This might be of help
Hotlinked/stolen from here: http://www.v6calibra.net/
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
I now own this one.
have you changed the ignition amplifier???
Fraz wrote:have you changed the ignition amplifier???
were is it located please
rich30mex wrote:Fraz wrote:have you changed the ignition amplifier???
It's here, just under the PAS reservoir bolted to the nearside chassis leg
I now own this one.
I now own this one.
Users browsing this forum: Google [Bot] and 20 guests
