speedo help! urgent
speedo help! urgent
Hi folks,not long finished my tx box/clutch on my turbo,my speedo doesn't work,all rest of dash is fine, I know it runs off the abs,does anyone have a pic of the multi plugs,pretty sure if plugged something in wrong
Re: speedo help! urgent
which plugs John the back of the clocks or the abs ? ether way you shouldnt be able to put them in the wroung way unless you try very hard, round hole square hole kind of thing
Abs,well engine bay end,havnt touched clocks in car,Il check again for abs light
it can only go in one way as well john, are you sure its not cable driven not sure when the ele one started
can you get reverse lights?? or do the only work at 60mph
I've got reverse lights, from what I can gather the reverse plug is on the end of the box facing n/s wheel, that only leaves a connection on top under the clutch cable, Not sure if this is the 1st gear boost limiter, Steve its a 96 turbo so pretty sure it's electrical
reverse light plug is near the gear linkage and first gear switch is down at the front of the `box.
specks
Theres a plug on the end of the box near the n/s wheel,If I put the car in reverse, the reverse lights come on, If I remove this plug the lights go out, So In my case reverse isnt anywhere near the selector
Anyone help! Really stuck here, ABS still working
4x4 light comes on at start up then goes off, stays off while driving
Neither my speedo or fuel computer are getting a speed reading, so it can't be the clocks
