speedo help! urgent
speedo help! urgent
by KERR_SE9 » Fri Feb 18, 2011 7:29 pm
Hi folks,not long finished my tx box/clutch on my turbo,my speedo doesn't work,all rest of dash is fine, I know it runs off the abs,does anyone have a pic of the multi plugs,pretty sure if plugged something in wrong
Re: speedo help! urgent
by v6 steve » Fri Feb 18, 2011 8:07 pm
which plugs John the back of the clocks or the abs ? ether way you shouldnt be able to put them in the wroung way unless you try very hard, round hole square hole kind of thing
by KERR_SE9 » Fri Feb 18, 2011 8:10 pm
Abs,well engine bay end,havnt touched clocks in car,Il check again for abs light
by v6 steve » Fri Feb 18, 2011 8:15 pm
it can only go in one way as well john, are you sure its not cable driven not sure when the ele one started
by Fraz » Fri Feb 18, 2011 11:05 pm
can you get reverse lights?? or do the only work at 60mph
by KERR_SE9 » Sat Feb 19, 2011 4:19 pm
I've got reverse lights, from what I can gather the reverse plug is on the end of the box facing n/s wheel, that only leaves a connection on top under the clutch cable, Not sure if this is the 1st gear boost limiter, Steve its a 96 turbo so pretty sure it's electrical
by specks » Mon Feb 21, 2011 2:35 pm
reverse light plug is near the gear linkage and first gear switch is down at the front of the `box.
specks
by KERR_SE9 » Mon Feb 21, 2011 9:03 pm
Theres a plug on the end of the box near the n/s wheel,If I put the car in reverse, the reverse lights come on, If I remove this plug the lights go out, So In my case reverse isnt anywhere near the selector
Anyone help! Really stuck here, ABS still working
by bodgetastic » Mon Feb 21, 2011 10:19 pm
You could try checking for any ABS fault codes
http://www.topbuzz1.carenthusiasts.co.uk/index.htm
by KERR_SE9 » Tue Feb 22, 2011 4:39 pm
4x4 light comes on at start up then goes off, stays off while driving
Neither my speedo or fuel computer are getting a speed reading, so it can't be the clocks
