Wierd Drivers door window
Hi,
Just a quick question. Im guessing that this problem is one that is suppose to happen but not sure why [img]/tongue.gif[/img]
When I do the windows up sometimes the drivers side goes all the way up and after a second or two it opens down a couple of inches.
Is this to prevent the sunroof getting damaged when I shut the door??
Is this really a standard thing or is my car possessed
Thanks
Thanks
DAN
lol, strange
Thought it might need to drop to prevent you popping the sunroof when you slam the door but my old 8v didnt do it.
The window doesnt go up when i lock the door so something is not right.
If I put the window back up after its come down it will stay there
Better get on the phone to the local church see if they can help [img]/smile.gif[/img]
cheers
cheers
DAN
<!--QuoteBegin-andycally+--><div class='quotetop'>(andycally)</div><div class='quotemain'><!--QuoteEBegin-->Dan
I have the exact same thing. How odd!?
Has only started happening after my cat 1 was put it, so i put it down to that.
Interesting!
[img]/biggrin.gif[/img]:D<!--QuoteEnd--></div><!--QuoteEEnd-->
Was it a black cat1 [img]/laugh.gif[/img] SPPOOOOKKKY :nana:
Interesting!
DAN
SukySaggi
Mine used to do that all the time, annoying as hell!!
I tried all the above advice, lubed the runners, reprogramming and even adjusted the angle of the glass (don't even go there).
After months of much cursing and wall punching someone suggested I change the switch unit, cost me £5 from a scrappy (off a Cav), took six and a half minutes to fit and has never done it since, perfect.
When you have explored all the probable causes then whatever is left, however improbable, must be the answer. Elementary my dear Dan.
KILLibra
For those who have it all...
Andycally
all i can say is that the lord works in mysterious ways. [img]/biggrin.gif[/img]
SukySaggi
