Wierd Drivers door window
by DAN » Wed Aug 04, 2004 11:48 am
Hi,
Just a quick question. Im guessing that this problem is one that is suppose to happen but not sure why [img]/tongue.gif[/img]
When I do the windows up sometimes the drivers side goes all the way up and after a second or two it opens down a couple of inches.
Is this to prevent the sunroof getting damaged when I shut the door??
Is this really a standard thing or is my car possessed :? :?
Thanks
DAN
by Smurf » Wed Aug 04, 2004 11:51 am
Nothing to do with the sunroof mate and I've never seen one do that - they should only bounce back if they get an obstruction, but then yours goes all the way and only comes down after a couple of seconds??
I'm going for the possessed idea :shock:
Smurf
by DAN » Wed Aug 04, 2004 11:56 am
lol, strange
Thought it might need to drop to prevent you popping the sunroof when you slam the door but my old 8v didnt do it.
The window doesnt go up when i lock the door so something is not right.
If I put the window back up after its come down it will stay there
Better get on the phone to the local church see if they can help [img]/smile.gif[/img]
cheers
DAN
by ODreams » Wed Aug 04, 2004 12:13 pm
Spooky!
ODreams
by andycally » Wed Aug 04, 2004 12:23 pm
Dan
I have the exact same thing. How odd!?
Has only started happening after my cat 1 was put it, so i put it down to that.
Interesting!
[img]/biggrin.gif[/img]:D
andycally
by DAN » Wed Aug 04, 2004 1:24 pm
<!--QuoteBegin-andycally+--><div class='quotetop'>(andycally)</div><div class='quotemain'><!--QuoteEBegin-->Dan
Interesting!
[img]/biggrin.gif[/img]:D<!--QuoteEnd--></div><!--QuoteEEnd-->
Was it a black cat1 [img]/laugh.gif[/img] SPPOOOOKKKY :nana:
DAN
by Stupink » Wed Aug 04, 2004 1:34 pm
reprogram your doors limits [img]/smile.gif[/img]
open door, click down button and hold till windows down then hold till you hear the click a few seconds later, repeat for upwards.. then try [img]/smile.gif[/img]
by SukySaggi » Wed Aug 04, 2004 1:43 pm
If Stupink's suggestion doesn't work, you will need an old preiset and a young priest. :mrgreen:
SukySaggi
by DAN » Wed Aug 04, 2004 6:42 pm
lol thanks for that stu
DAN
by philangel » Wed Aug 04, 2004 11:01 pm
try giving the guides a spray with a silicon fluid,they sometimes get gunged up with dirt and this causes the obstruction sensor to kick in which will drop the window a couple of inches.does the window stay closed if you keep the little black button pressed while you close it?
philangel
by DAN » Thu Aug 05, 2004 1:32 pm
Im not sure but I will give it a try
Thanks
DAN
by KILLibra » Wed Aug 11, 2004 10:13 am
Mine used to do that all the time, annoying as hell!!
I tried all the above advice, lubed the runners, reprogramming and even adjusted the angle of the glass (don't even go there).
After months of much cursing and wall punching someone suggested I change the switch unit, cost me £5 from a scrappy (off a Cav), took six and a half minutes to fit and has never done it since, perfect.
When you have explored all the probable causes then whatever is left, however improbable, must be the answer. Elementary my dear Dan.
KILLibra
by andycally » Wed Aug 11, 2004 10:25 am
Well... I took the 'old priest and young priest' advice and its seems to have stopped now!! :wink:
Not really.... It just hasn't happened in a while! [img]/biggrin.gif[/img]
What a pointless reply this was..... :oops:
andycally
For those who have it all...
by SukySaggi » Wed Aug 11, 2004 10:41 am
Andycally
all i can say is that the lord works in mysterious ways. [img]/biggrin.gif[/img]
SukySaggi
by skellem » Wed Aug 11, 2004 11:59 am
I cleaned the door rubbers (the ones the glass slides on) and sprayed silicone spray all over them. Works fine now!
skellem
