C20LET ECU TYPES??
Re: C20LET ECU TYPES??
Whats this from then?? I dont recognise it???
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... fe=sidebar
superfox233
He's just pm'd me back:
Everything printed on the front is as follows: WJ, Bosch 0 265 100 040, 9460812
superfox233
god knows what thats off, but i'd be supprised if its c20let. never seen one that shape before.
Here is a list of ECU's used in Calibra's (How accurate it is, not sure)
http://www.v6calibra.net/motonic/full%2 ... 0range.htm
is there any way to deactivate immo from a HD ecu and use it on the early calibra's?
vaggelis00
is there a how to guide?
what exactly should i change?
i just have to replace the 2 OEM chips with 2 OEM chips from an early ecu and it will work?
vaggelis00
i dont want to increase the horse power. if i use the OEM chips from a PJ or PK ecu will this change deactivate the immo?
vaggelis00
so the 100% way to deactivate the immo is to use chips from EDS or VMAX or something like that?
vaggelis00
i've opened the HD ecu. under the TOP chip in the ecu there is the immo chip and there is no way to remove it. any ideas???
vaggelis00
Users browsing this forum: No registered users and 47 guests
