C20LET ECU TYPES??
C20LET ECU TYPES??
by superfox233 » Fri Mar 13, 2009 6:55 pm
Code: Bosch WJ.
Does this ecu have the immobiliser etc?? :oops:
superfox233
Re: C20LET ECU TYPES??
by superfox233 » Fri Mar 13, 2009 7:44 pm
Whats this from then?? I dont recognise it???
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... fe=sidebar
superfox233
by tazz666 » Fri Mar 13, 2009 8:18 pm
get the part number from the boy and i will have a look for you :D
by superfox233 » Fri Mar 13, 2009 11:33 pm
jus pm'd him thru ebay!! letcha y'all know wen he replies!!
superfox233
by superfox233 » Sat Mar 14, 2009 7:49 pm
He's just pm'd me back:
Everything printed on the front is as follows: WJ, Bosch 0 265 100 040, 9460812
superfox233
by Stupink » Sat Mar 14, 2009 8:14 pm
god knows what thats off, but i'd be supprised if its c20let. never seen one that shape before.
by superfox233 » Sat Mar 14, 2009 9:09 pm
thats what i was thinking....... :?
superfox233
by RobbieV » Sat Mar 14, 2009 9:21 pm
Here is a list of ECU's used in Calibra's (How accurate it is, not sure)
http://www.v6calibra.net/motonic/full%2 ... 0range.htm
by vaggelis00 » Thu Jul 02, 2009 9:49 am
is there any way to deactivate immo from a HD ecu and use it on the early calibra's?
vaggelis00
by vaggelis00 » Thu Jul 02, 2009 12:31 pm
is there a how to guide?
what exactly should i change?
i just have to replace the 2 OEM chips with 2 OEM chips from an early ecu and it will work?
vaggelis00
by vaggelis00 » Thu Jul 02, 2009 8:22 pm
anyone????
vaggelis00
by vaggelis00 » Fri Jul 03, 2009 12:07 am
i dont want to increase the horse power. if i use the OEM chips from a PJ or PK ecu will this change deactivate the immo?
vaggelis00
by vaggelis00 » Fri Jul 03, 2009 9:52 am
so the 100% way to deactivate the immo is to use chips from EDS or VMAX or something like that?
vaggelis00
by vaggelis00 » Wed Jul 15, 2009 9:56 am
i've opened the HD ecu. under the TOP chip in the ecu there is the immo chip and there is no way to remove it. any ideas???
vaggelis00
