Vectra cam sensor ?
Vectra cam sensor ?
by BazV6er » Sat Nov 08, 2008 10:26 pm
been looking at the cam sensors to fix tinas car but the cam sensor she has got has a code of:
siemens 5WK9 055 2 and theres a small code underneth :24 445 139
but everywhere like autovaux , lm andebay are completely diff:
http://cgi.ebay.co.uk/Camshaft-Cam-Sens ... 1|240:1318
autovaux
lmf
so which one do we get?
by tazz666 » Sat Nov 08, 2008 10:30 pm
what engine is the vectra mate ,? because if it is a ecotec there is an updated sensor
by BazV6er » Sat Nov 08, 2008 10:34 pm
okay taz its a v reg facelift vectra b with a oblong plug cam sensor where the original wiring has been soldered together to connect to a 3 pin plug if that makes sense?
by cornishtaz » Sat Nov 08, 2008 10:35 pm
Baz just checked EPC and part no is 90458252
cornishtaz
by cornishtaz » Sat Nov 08, 2008 10:38 pm
Best thing to do is phone vaux and quote your reg/chassis no.and let them know its been modified
cornishtaz
by tazz666 » Sat Nov 08, 2008 10:38 pm
iot does mate as it had tho older one in it and it had the conversion done on it
by BazV6er » Sat Nov 08, 2008 10:41 pm
by cornishtaz » Sat Nov 08, 2008 10:45 pm
Baz is there a GM part no?
cornishtaz
by tazz666 » Sat Nov 08, 2008 10:46 pm
as cornishtaz says mate take it to vauxhall they will sort you out
by BazV6er » Sat Nov 08, 2008 10:46 pm
strange thing is the one that i posted from ebay the siemens part is literally identical but a few numbers look different?
could it be this one ?
from ebay link above :
SIEMENS PART NO 9WK90551
by BazV6er » Sat Nov 08, 2008 10:48 pm
i was wondering baz if the GM part was :
24 445 139: as there is on the right a GM logo
by cornishtaz » Sat Nov 08, 2008 10:48 pm
Have a look through these
Cam sensors
cornishtaz
by BazV6er » Sat Nov 08, 2008 10:55 pm
i think thats the same link as i posted but i did find something some added :
http://cgi.ebay.co.uk/vectra-1-8-16v-2l ... 1|240:1318
this timing belt cover will fit an 1800 16v or 2 litre 16v vectra from 1995-1999 unless the modified part of the wiring loom has already been fitted, the modified loom has a slightly oval shape instead of just an oblong, if you are in any doubt please look at the on on your car and compare it before buying, if your management light is on and the car wont rev over 4500rpm, this will be the fault.
by tazz666 » Sat Nov 08, 2008 10:58 pm
it sounds like you deffinatley have the modified sensor mate when i worked for vauxhall it came with the modified loom aswell
by cornishtaz » Sat Nov 08, 2008 11:04 pm
That would match upto what Neil said about making the slot larger around the area of the camsensor as you've got the modified version.
cornishtaz
