Vectra cam sensor ?
Vectra cam sensor ?
been looking at the cam sensors to fix tinas car but the cam sensor she has got has a code of:
siemens 5WK9 055 2 and theres a small code underneth :24 445 139
but everywhere like autovaux , lm andebay are completely diff:
http://cgi.ebay.co.uk/Camshaft-Cam-Sens ... 1|240:1318
autovaux
lmf
so which one do we get?
autovaux
lmf
cornishtaz
strange thing is the one that i posted from ebay the siemens part is literally identical but a few numbers look different?
could it be this one ?
from ebay link above :
SIEMENS PART NO 9WK90551
i think thats the same link as i posted but i did find something some added :
http://cgi.ebay.co.uk/vectra-1-8-16v-2l ... 1|240:1318
this timing belt cover will fit an 1800 16v or 2 litre 16v vectra from 1995-1999 unless the modified part of the wiring loom has already been fitted, the modified loom has a slightly oval shape instead of just an oblong, if you are in any doubt please look at the on on your car and compare it before buying, if your management light is on and the car wont rev over 4500rpm, this will be the fault.
