Rack question 95 cali 8v with p/s
by DiDi16v » Tue Jul 22, 2008 9:03 pm
Hi all my wife cali has a knocking coming from somewhere, now bazzv6er mentioned the rack maybe shot.
My question is this, if i grab the track rod control arms where they bolt on to the rack there is movement up and down, should this be the norm or does it sound like the rack has died.
DiDi16v
by Calibra_Mike » Tue Jul 22, 2008 9:37 pm
how much play? Best way to tell would be to get the whole front end jacked up and then get someone to turn the steering wheel from lock to lock and look out for any unusual noises, could be a simple thing like a knackered or loose track rod end, mine knocked then i noticed a loose nut on the drivers side track end, tightened it and its been fine since...
I have a spare rack if you do require one...
by DiDi16v » Wed Jul 23, 2008 5:06 am
cool ok m8 will try that, i think the rack i have is a ZF should that be of any use, will let you know on the rack soon as, live about 30 miles miles from you, how much for the rack?
DiDi16v
by Calibra_Mike » Wed Jul 23, 2008 7:01 am
I think the one I have is a ZF can double check if you do require it, will only want £25 for it...
but check that it is the rack first as its a bit of a pig of a job to change so only do it if need be...
Users browsing this forum: Majestic-12 [Bot] and 16 guests
