DESPERATE!!!!!!!!!! HEEELLLPPPP
Ok, finished delocking the cally with some vectra doorhandles, removed locks and taped up microswitches, problem is I caught one of the switches and car now thinks it is deadlocked and alarm keeps going off every time I open a door. Tried to press again but wont unlock/turn off alarm, what am I doing wrong? Got alarm module in footwell, which wire needs positive/negative pulse to turn off the alarm and turn off deadlocks????? Supposed to be going out in car tomorrow, no chance unless I can sort this problem out tho!!!! Someone pleeeaaassseee help meee, driving me mad!!!!! Thanks guys Mark.
markybrisca
markybrisca
Right, nearly there, looks like I have damaged the locking relay. Am I right in thinking the lock/unlock wires should be live and the alarm will pulse them with a negative pulse to lock/unlock the doors. If so I can take 2xlive feeds to each of lock/unlock and all will be good. This means door motors will be working as slave instead of in factory system through locking relay. I have disconnected all standard alarm multiplug and fitted complete system which has turned into an epic. AND ALL BECAUSE I DIDNT WANT DOOR HANDLES ON MY CALLY!!!!!!!!
markybrisca
Apparently If you use your screwdriver to force the handle out of the door you can gain entry. Although you will leave a massive hole i doubt that the car thief is bothered about that.
Anyway i wouldn't of put a Calibra high up in the at risk stakes, what about all those modern Astra Turbo's waiting to be stolen?
well i learnd the hard way...lol
i have no boot lock and de locked handles and the battery went dead so needed to call mr AA man out to get it open
so i will now be tacking a feed from the battery and putting it some where i can get access to with jump leads if this EVER happens again.....lol
