Changing Suspension
by Calibra_Mike » Thu Aug 23, 2007 10:47 pm
Right as one of my front shocks is dead I will be replacing the pair, at the same time I will also be fitting a set of new springs all round, lowered by 40mm not sure what its lowered by at the moment... what I need to know is what else will need replacing at the same time as in the Haynes manual it says a load of stuff will need replacing like snap rings, ball joint locking nuts etc... Does this all REALLY have to be replaced? Has anyone on here done this themselves before? What advice do you give as I will be doing this myself along with the help of my friend, both of us have done suspension before just not on a calibra...
by Fraz » Thu Aug 23, 2007 11:09 pm
TBh if I was stripping down teh front suspension, and I did not know how long the arms had been on there..I would change them at the same time. It is advisable to change the lock nuts for new ones...but few do (even I don't )
If your going to do the shocks then a few tips on this thread
<a href="http://www.clubcalibra.net/forums/index.php?showtopic=1625&b=1&st=0&p=0&#entry0" target="_blank">http://www.clubcalibra.net/forums/index.ph...p=0&#entry0</a>
by BazV6er » Fri Aug 24, 2007 11:28 pm
mike
i was lucky to get a brand new set of cavalier/calibra wishbones and anti roll bar links for 20 quid from my younger brother as he bought a red 16v xe but sold it for a cavgsi
i replaced the wishbones /sleeves and new bolts as well as the new arb links . i also used the new locking nylon nut rather than the old castellated nut i found .
i think i got a howto guide from cavweb i think , did need to use the haynes manual
by Chavtastic » Sat Aug 25, 2007 9:13 pm
Yeah do the lower arms and droplinks. I'd also check the track rod ends over as well. They are only £9 new so you might as well.
It's one of those things where a lot of jobs become accessible by doing this. Are your CV's leaking? Good chance to do them.
by Calibra_Mike » Sat Aug 25, 2007 10:16 pm
CV joints look ok, i expect ill do the track rod ends as I did them on my old cavalier and they are only a 20min job... Cheers for the advice guys, im looking at trying to get as much replaced as i can when i do it, just makes sense rather than having to come back and do it later...
