Throttle Position Sensor
<!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->right i had a look on here <!--fontc--></span><!--/fontc--><a href="http://www.max-boost.co.uk/max-boost/Gotchas_LET.htm#TPS" target="_blank"><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->http://www.max-boost.co.uk/max-boost/Gotchas_LET.htm#TPS<!--fontc--></span><!--/fontc--></a><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--> cos everytime i touch the accelerator im getting a engine warning light on my dash and jerkiness as explained in another thread. <!--fontc--></span><!--/fontc-->
<!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo-->[/size]<!--fontc--></span><!--/fontc-->
<!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo-->getting way off readings when i checked with the multimeter compared to the readings on the max boost page. does anyone know if the same readings wud be expected from an xe rather than the let he's talkin about. and if they are does anyone know what the readings should be?<!--sizec--></span><!--/sizec--><!--fontc--></span><!--/fontc-->
<!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo--><!--sizec--></span><!--/sizec--><!--fontc--></span><!--/fontc-->
<!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->[size=2]in sayin that now there was a bit of grease on it and was hard to get a reading to be honest. could this be causing the problem? what would be the best wat to remove the greasey crud from the pins of the connector? carb cleaner do it?<!--sizec--></span><!--/sizec--><!--fontc--></span><!--/fontc-->
johnny_adidas
ive finally had to admit defeat and am waiting on a opel dealer to call me back with a price for cambelt change and diagnostic to find out what is causing the jerking. ecu light is now on constantly and getting less and less power every time i drive her. have checked all the intake from airbox to the throttle body and nothing seems amiss. hopefully they will be able to find the problem with the tech 1 and i might then be able to change it myself
johnny_adidas
ok tink it may not be as bad as first thought. hopefully they will do the work if i can source the parts myself.
they said it wud take 2 hours labour. so say 510-[196(timing kit)+36(drive belt)+106(waterpump)] =172 {all exclusive of VAT}
so dats working out about 100 an hour labour. so if i get the parts myself. im working out about 80(timing kit)+0(already have drivebelt at home)+50(waterpump) so dat wud be 350 total say including fitting and even if i had to pay 40 for the tech 1 test then i wudnt mind. plus i reckon if im doin it that way ill just get the tech 1 done now and find out whats faulty and then order any extra parts i need from the same crowd online to reduce the postage.
johnny_adidas
ok im kinda getting tired of saying this over and over!!!!!
<!--QuoteBegin-johnny_adidas+--><div class='quotetop'>(johnny_adidas)</div><div class='quotemain'><!--QuoteEBegin-->not logging any fault codes. other than that id know where to start myself<!--QuoteEnd--></div><!--QuoteEEnd-->
johnny_adidas
Users browsing this forum: No registered users and 69 guests
