Hiya Need Help With Sunroof Please!!would Be Much Appreciate
by aliakaraza » Wed Nov 16, 2005 6:08 am
HIYA,IM HAVING PROBLEMS WITH MY SUNROOF,IT TILTS UP,BUT DOES NOT TILT BACK DOWN, AND I WAS WONDERING WEATHER ANYONE CAN HELP ME WITH THIS,AS I HAVE COVERED MY SUNROOF WITH A BIN BAG,LOLZ, SO PLEASE PLEASE CAN SOMONE HELP ME!!! [img]/smile.gif[/img]
AS YOU CAN SEE IN THE PICTURE BELOW THE BIN BAG LOOKS AWFUL! BTW CHECK OUT THE FLIP TONE RIMS,
aliakaraza
by J80PPS » Wed Nov 16, 2005 8:55 am
I had the same problem with my 8Valve Calibra a year ago. Easy solution, sell it, that's what I did !
The sunroof is so complicated that I couldn't even get a local garage that wanted to look at it and the Haynes manual is no use either.
I think if you have tried manually closing it with the large Allan Key and it didn't work then you are in for a hefty bill at the main dealer.
J80PPS
by icewizard » Wed Nov 16, 2005 1:03 pm
If you have a search on here there is loads of info and procedeures about fixing the sunroof. The most common problem I've found is the screws come loose that attach the motor to the sunroof. You might want to check these first although they can be a bit tricky to get too.
icewizard
by jimbohotpants » Wed Nov 16, 2005 3:38 pm
yeah, like Icewizard said...... and if the roof is fooked completely you can probably get your mits on a second hand complete roof from here or ebay for less than a fix job at the dealers:)
jimbohotpants
thnx
by aliakaraza » Wed Nov 16, 2005 9:27 pm
thanx alot, your help has been much appreciated,thank you!!!!
aliakaraza
by Animal » Wed Nov 16, 2005 9:45 pm
Wow! That is a nice motor!!!!
Can u hear the motor running? Or is the motor just not doing anything? If it is moving it will either be as Icewizard said the motor coming loose or the same problem I had with mine the cable had gone to the end and popped off. (I'm asuming u have a twin cog one due to your v grille)
by sofaman » Thu Nov 17, 2005 5:09 am
if you remove the motor you will be able to push it to the closed position.
Might save you a bob or two untill you can figure out whats wrong
sofaman
Users browsing this forum: No registered users and 86 guests
