Hiya Need Help With Sunroof Please!!would Be Much Appreciate
HIYA,IM HAVING PROBLEMS WITH MY SUNROOF,IT TILTS UP,BUT DOES NOT TILT BACK DOWN, AND I WAS WONDERING WEATHER ANYONE CAN HELP ME WITH THIS,AS I HAVE COVERED MY SUNROOF WITH A BIN BAG,LOLZ, SO PLEASE PLEASE CAN SOMONE HELP ME!!! [img]/smile.gif[/img]
AS YOU CAN SEE IN THE PICTURE BELOW THE BIN BAG LOOKS AWFUL! BTW CHECK OUT THE FLIP TONE RIMS,
aliakaraza
I had the same problem with my 8Valve Calibra a year ago. Easy solution, sell it, that's what I did !
The sunroof is so complicated that I couldn't even get a local garage that wanted to look at it and the Haynes manual is no use either.
I think if you have tried manually closing it with the large Allan Key and it didn't work then you are in for a hefty bill at the main dealer.
J80PPS
Wow! That is a nice motor!!!!
Can u hear the motor running? Or is the motor just not doing anything? If it is moving it will either be as Icewizard said the motor coming loose or the same problem I had with mine the cable had gone to the end and popped off. (I'm asuming u have a twin cog one due to your v grille)
