probelm
probelm
by plug » Mon Mar 14, 2005 10:06 pm
having probelm was engine management warning light keeps going on and off been to local vaux dealer and tells me they cant find anything wrong any idas since im a new member
plug
by Fraz » Mon Mar 14, 2005 10:10 pm
well firstly it would help if we knew what engine model/year the car was?
oh and welcome
by plug » Mon Mar 14, 2005 10:15 pm
1996 2.5 v6 no mods on yet
plug
by plug » Mon Mar 14, 2005 10:19 pm
<!--QuoteBegin-Fraz+--><div class='quotetop'>(Fraz)</div><div class='quotemain'><!--QuoteEBegin-->well firstly it would help if we knew what engine model/year the car was?
oh and welcome<!--QuoteEnd--></div><!--QuoteEEnd--> its a v6 2.5 on a 1996 plate
plug
by Stupink » Mon Mar 14, 2005 10:42 pm
I don't know squat about the v6, but its allways worth trying to read the fault codes yourself first [img]/smile.gif[/img]
if you go to alans site <a href="http://www.topbuzz.co.uk" target="_blank">www.topbuzz.co.uk</a> there is a guide there to reading the ecu fault codes.. I've known people go to vaux who cant find anything wrong, then read out fault codes this way, its like vaux dont even bother to test it..
welcome to the club tho [img]/smile.gif[/img]
cheers
by plug » Mon Mar 14, 2005 10:50 pm
cheers stu a bit rusty on computer ill try any way
cheers chris (leicestershire)
plug
by Stupink » Mon Mar 14, 2005 10:57 pm
heres a direct link for you then, hope it helps.. reading the codes is fairly easy.. im assuminhg you can do it ok on the v6 etc.. i've never had one or paid much attention to how they work really.
by Stupink » Mon Mar 14, 2005 11:00 pm
OR alternatively, i could include the link in my post
<a href="http://www.topbuzz.co.uk/info/fault_codes/fault_codes.htm" target="_blank">http://www.topbuzz.co.uk/info/fault_codes/fault_codes.htm</a>
by plug » Mon Mar 14, 2005 11:06 pm
what mods should i start with ive got 17's on and a custom grill because some f***** broke my badge off
plug
by projectx » Mon Mar 14, 2005 11:14 pm
I'd start by working out why your ECU light is coming on, cure it, then start pouring the money into modding [img]/smile.gif[/img]
After that, it depends on whether you're after looks or performance?
If the light is coming on and off, it is probably storing the codes which you can read as mentioned above. Is the car actually showing any signs of problems, or is it just the light you're seeing?
projectx
by plug » Mon Mar 14, 2005 11:18 pm
light comes on proformance drops
plug
by Peachperformance » Mon Mar 14, 2005 11:24 pm
Sounds like a cam sensor then, but as others have said use the Topbuzz website and read the codes of first before spending on a new one.
Peachperformance
