Help Me!!!!!
Help Me!!!!!
by PAULJOHNSON » Mon Feb 21, 2005 10:27 pm
can anyone please,please help me????????
it all started when i decided to change all my control switches to 'blue'l e d style-i have been buying the switches from ebay with no problems,until now-i replaced the rear heated window swicth with a'blue'one......and nothing happened!so i put my origanal one back in-that doesn't work now either??????i have checked the fuse in the fuse box(under dash)but all fuses are ok.i have tried numerous switches since and nothing-WHATS WRONG?????also having been speaking to loads of people about this i find out that my heater control display is supposed to light up!!!but mine doesn't!!also i find out that i should have more lights on the dash display when i turn the key(bulb check for example)
my calibra is a 1993/4 se-origanaly an 8v,is there a differance in elctronic display speck(apart from digital clock+air con+extra fog switches)?
<!--sizeo:6--><span style="font-size:24pt;line-height:100%"><!--/sizeo-->[/size]
[size=6]help me please!!!!!!<!--sizec--></span><!--/sizec-->
PAULJOHNSON
by Fraz » Mon Feb 21, 2005 10:44 pm
Not wishing to state the obvious here...but you have turned the engine on? just the Calibra heated rear window only works with the engine running
and yes the 8V did not have all the check lights that the 16v has...cant remember which but things like water and oil level spring to mind
by jayl645 » Tue Feb 22, 2005 12:22 am
hehe i bet the engine was off,
jayl645
by PAULJOHNSON » Thu Feb 24, 2005 9:53 pm
THANKS FOR THE INPUT BOYS!yes the engine was on,ive tried whilst on the move-but nothing-is there any other relays or something?
PAULJOHNSON
by Fraz » Thu Feb 24, 2005 10:44 pm
well there is a relay (cant remember where)as the heated rear window is on a timer (only stays on for 15 mins IIRC)
will have a look as I think I have a relay location diagram somewhere
by Fraz » Thu Feb 24, 2005 11:01 pm
should be the relay at bottom right in fuse box
by PAULJOHNSON » Thu Feb 24, 2005 11:15 pm
cheers mate-will check it out,hopefully that is all it is-i don't fancy taking the dash out just for this!!will let you know if you are right,cheers!
PAULJOHNSON
by PAULJOHNSON » Sat Mar 12, 2005 7:51 pm
guess what???????i sorted it!the problem was.....when i replaced the switches,i must of puched the 'new'switch in to hard and pushed the 'wiring; plugs back!so the switch wasn't making a complete connection-after getting realy anoyed with this not working properly,i stripped the dash...and there it was staring me in the face-what a plank!!!thanks for you help tyhough!
PAULJOHNSON
Users browsing this forum: Bing [Bot] and 32 guests
