wheels
by hillcrew » Thu Mar 04, 2004 12:47 am
is it possible to fit 19" wheels on to the calibra with out any modifications
hillcrew
by Topbuzz » Fri Mar 26, 2004 7:22 pm
yes.
its already been many times and from members on this forum.
but if you want full lock on your front wheels, then prepare to do some mods.
Alan Knight (Topbuzz)
W: www.topbuzz.co.uk
E: webmaster@topbuzz.co.uk
by hillcrew » Wed Apr 28, 2004 10:03 pm
do you know if these wheels will fit this is the info not sure what it all means 8.0 x 18 e+15/41 cheers danny
hillcrew
by thesaint » Thu Apr 29, 2004 9:15 am
8.0 x18= 8 inch wide rims is about a 215mm wide tyre with 18inch diameter. not sure about the rest of that info e+15/41??? this sounds like pcd and offset, not sure what the cally specs are for this.
I'm not helping much am i..... [img]/sad.gif[/img]
thesaint
by thesaint » Thu Apr 29, 2004 10:51 am
I lied, 8 inch wide is about 225/235mm. i'm running 215's and the wheels almost poke out from under the arches. Not sure if thats an offset issue though.
thesaint
by Topbuzz » Thu Apr 29, 2004 12:05 pm
It will be offset or width of tyre, or even both. I've got 18's on mine, think the offset is et42. No problems with the arches what so ever, even at fully lock.
