where is the buzzer for the lights
by big_gordy » Tue Mar 02, 2004 2:06 am
:roll: where will i find the bit that makes the noise when u leave yer lights on & u open the door?? mines dont work
anyone got some pics on how to fix it ect
by ecosseM » Tue Mar 02, 2004 5:17 am
awrite mate, i think that its a relay in the fuse box. will have a look tomoz. its 4am'ish n am just in fae work
ecosseM
by dazjb » Tue Mar 02, 2004 9:59 am
Aye it is in the fusebox. The part no. for the older nasty sounding buzzer is 90 240 665, the newer two-tone sounding one is part number 90 464 777.
I have lifted this info from CavWeb, for more info click on the link below :-
<a href="http://www.cavweb-forums.co.uk/showthread.php?t=35" target="_blank">http://www.cavweb-forums.co.uk/showthread.php?t=35</a>
dazjb
by Kieran_Burns » Tue Mar 02, 2004 1:24 pm
you mean the buzzer / two tone is in there?
Are they interchangeable?
Kieran_Burns
by dazjb » Tue Mar 02, 2004 2:15 pm
<!--QuoteBegin-Kieran_Burns+--><div class='quotetop'>(Kieran_Burns)</div><div class='quotemain'><!--QuoteEBegin-->you mean the buzzer / two tone is in there?
Are they interchangeable?<!--QuoteEnd--></div><!--QuoteEEnd-->
If you mean can you change the old style buzzer for a new style two-tone one then yes you can, they just plug straight in.
You can also fit the nicer sounding buzzer from a Renault with a bit of wire swapping at the back of the fusebox, check here ....
<a href="http://www.cavweb-forums.co.uk/showthread.php?t=90" target="_blank">http://www.cavweb-forums.co.uk/showthread.php?t=90</a>
dazjb
by dazjb » Tue Mar 02, 2004 3:50 pm
As your looking into the fusebox the relay is the first one in the top left, it should have the number 90 240 665 on it. If your going to fit the newer two-tone one from a later Calibra then it should just pop straight in there.
dazjb
