how do i know if my alarm is activated?
RE: Internet explorer problem HELP!
hello you lot
i've a 96 8v beauty
when i lock the car are the hazzard lights supposed to flash??
definatley an alarm in there its got sensors n stuff [img]/biggrin.gif[/img]
not an aftermarket one
just wondering is it meant to tell me its engaged or not?
i've a 96 8v beauty
Enigmatic
RE: F28 gear oil?
Mine has flashed a few times when arming and when going off, but not most of the time, the way i used to test it was to get someone to lock the door and watch the led till it was armed, while i left the bonnet open and held the bonnet sensor down, then when i let it up i knew it was armed,
Theres something about how the led flashes ie slowly, rapidly or on all the time, but ive had the alarm manual pinched so cant say which is which flashing rate.
ROG
RE: how do i bleed 4x4 steering
my bonnet sensor was removed by the previous owner. how can i get one and how do i wire it back? does it go on a connector or?
tb303
RE: how do i know if my alarm is activated?
Should be a connector floating about near theTop right side(when looking from front bumper)between the fuse box and alarm horn. To get another one post up on someone who is breaking that model of cally you have.
Mac
RE: air filter
hi all,ive got a 93 2ltr 8v and i have the same problem i dont know when my alarm is armed!!!,i did the bonnet trick and the alarm went off but how do i check if the alarm will go off when the doors open or the boot gets opened (as i have a lot of ice),and my fuse block in the enging bay has been striped too,(strange)
jayl645
o2 sims YET ANOTHER free sim OFFER (
Do the same as the bonnet switch but use the door switch, It's a little plastic cylider that sticks out about an inch on the door frame, The same with the boot switch mate.
Mac
