wire colour
e-bay
ok i cut the lead that goes into my volt/oil gauges, but the wire is twisted and i'm not sure which wire to join to which wire, mainly because the plastic sleeve has come off two of the wires! looking at the top of the connector as it would plug in, wire 1 is brown, wire 3 is black. anybody know what colour wires 2 and 4 are?need to extend wires to fit gauges above glovebox.
cheers guys [img]/biggrin.gif[/img]
Tattooman
Hi, mine does that aswell, i cleaned the connector on the pressure sender switch but sometimes it still goes way over and other times its normal (i think) Its something i dont know a lot about maybe someone else can post an answer
[img]/smile.gif[/img]
Cheers Rob
Cheers Rob
