AUTO WINDOW OPEN/CLOSE
by jeff » Fri Oct 08, 2004 2:35 pm
Hi i have 1997 se8 and the window auto open/close stopped working also door key wont close window also with console button and doors lock i have tried resetting switch etc but no good any ideas please ?
jeff
by SukySaggi » Mon Oct 11, 2004 12:34 pm
Does the window open at all? If it doesn't sounds like the motor needs replacing.
SukySaggi
by jeff » Thu Oct 14, 2004 10:32 am
YES EVERYTHING WORKS FINE BUT NOT THE AUTO FUNCTION
jeff
by SukySaggi » Thu Oct 14, 2004 10:41 am
When I changed my battery, the auto function on my windows stopped. What I did was start the car, open the window fully holding the switch down, then close the window fully holding the switch down. Did this twice (ie. open, close, open, close.) After this this window starting working fine. (ie one touch fully open, one touch fully closed)
Try that, it may work.
SukySaggi
by Rusty_CallyT » Thu Oct 14, 2004 11:33 am
wind it down, then wind it up and hold the button for 5 seconds longer than when the window is fully up
Rusty_CallyT
by jeff » Thu Oct 14, 2004 4:22 pm
yes i have done the resetting proceedure and still it will not work i did wonder if it was a relay but i do not know where it it
jeff
