overhaul begins part 2 (se6)
by craigyboy » Tue Aug 25, 2015 8:39 pm
after the se6 sitting for a while I thought it was time to
start the project again. I have stripped out the full interior
cut out the bad bits in the floor.I used cardboard to mark out
the templates and used them to mark up the steel to cut it
I then welded them in place.
Once the engine was out I noticed the same old bit was rotten on the bulkhead, so
I cut that out and welded in a new part of steel.I then tidyed up the rest of the engine
bay and gave it a lick of paint.
[URL=http://s1205.photobucket.com/user/craig172/media/billing/2015-06/20150822_172957.jpg.html]Image[/URL
Re: overhaul begins part 2 (se6)
by craigyboy » Tue Aug 25, 2015 8:48 pm
Gave the engine bay a clean and a couple of coats of paint
Also had to make up a new off side brake pipe as the old one
was badly corroded.
The next job was to get the block tidied up , so I brushed it with
engine gunk and pressure washed it.I then gave it a couple of coats
of engine lacquer .
by craigyboy » Tue Aug 25, 2015 9:05 pm
In wrong order but heres a few pics of the engine coming out.
by KERR_SE9 » Tue Aug 25, 2015 9:06 pm
Nice work!
by rich30mex » Tue Aug 25, 2015 9:26 pm
Looking good pal
by craigyboy » Tue Aug 25, 2015 10:06 pm
Thanks guys, pity the pictures have came on the wrong way.
Next job is to take off the rocker cover,sump and engine brackets
and get them down to the powder coaters.
by v6 steve » Tue Aug 25, 2015 10:44 pm
looking good mate
turn up the power on your welder youll get better welds
by Callyscot » Tue Aug 25, 2015 11:03 pm
nice work Craig :clap:
Best Presented Billing 2009
Best Interior Billing 2010
Flooded out 2012
Best Interior 2014
by Mark1 » Wed Aug 26, 2015 6:00 am
Have you moved, as the suns out :)
by sealeysonic » Wed Aug 26, 2015 10:28 am
Great progress....!
by craigyboy » Wed Aug 26, 2015 4:55 pm
The welds not the best because i'm using flux cored wire instead of gas
I've been told in the past that it's a tidier weld with the gas.
by craigyboy » Sat Sep 12, 2015 7:15 pm
Picked all my engine parts and a few other bits up from
the powder coater's yesterday.So all I am waiting on
now is for my silicone hoses to arrive and I will be
putting the engine back in.
by rich30mex » Sat Sep 12, 2015 7:32 pm
Looks great pal
by craigyboy » Fri Oct 09, 2015 4:53 pm
After a bit of hastle receiving my hoses I have eventually got the engine
fitted.I have a also purchased a stainless manifold.So just a few other
bits to get done and i'll get it all back together before getting it to the
painters.
Users browsing this forum: Bing [Bot] and 12 guests
