fault codes
fault codes
Rite lads i did the paperclip test do day on the calibra cause it wasn't tuning right,fault codes 0335,0340,0351,i know 0335 and 0340 are to do with camshaft sensor and 0351 is something to do with the coil,my question is if the camshaft sensor is gone would it effect the ignition coil
Re: fault codes
Symptoms are,when i was driving yesterday car had a misfire rev counter went nuts and loss of power and engine light on,turned it off for a bit and started it and went away fine again,now the same has happened again today
Re: fault codes
Ordered both sensors,so hopefully it will sort the problem,thanks for the advice
Users browsing this forum: No registered users and 86 guests
