Fuel Pipe Replacement
by DanSE4 » Wed Mar 05, 2014 3:20 pm
Going to be replacing all of the fuel lines from rail to tank this weekend.
Does anyone know if you can get access to where they connect to the unit on top of the tank without actually dropping the tank?
Cheers.
Calibra SE4 3.2 V6 + F28
A Couple of German Cars!
Re: Fuel Pipe Replacement
by DanSE4 » Wed Mar 05, 2014 4:18 pm
I'm replacing everything (last MOT flagged that the pipes from the filter going back to the tank weren't too good).
Currently have a combination of metal, rubber & SS braided hose where I've replaced bits in the past so I've just bought an 8m length of SS braided hose to do everything from rail to tank in a continuous pipe (with the exception of splitting it at the filter of course).
For some reason I had it in my head that there was a cover (or something) under the boot carpet to get at the unit on the top of the tank, too much cheese perhaps?
by DanSE4 » Wed Mar 05, 2014 6:24 pm
It is a flexible one from the filter to the tank & that's the one that's perished on mine. Been meaning to replace the lot with a single at piece at some point though so now's as good a time as any.
Was just clutching at straws really to see if it was possible to get at the connections to the sender on the tank without actually dropping the tank.
by GreyDJ » Thu Mar 06, 2014 1:00 am
No cheese, that's what you do in a Cavalier (non Turbo) under the rear seat. Not sure if any Calibras have the hole.
Cavalier CDi 96 Grey
Cavalier SRi 93 Satin Red
Cavalier Mk2 CD130 86 White
by DanSE4 » Thu Mar 06, 2014 10:06 am
I didn't think I was talking complete b*******.
Had a few Cavs in the past so that must be what I was thinking of.
by DanSE4 » Mon Mar 10, 2014 3:44 pm
Sorted now.
Nasty old ones....
Nice new ones....
:D
by Teejay » Mon Mar 10, 2014 4:31 pm
Nice work fella
by DanSE4 » Mon Mar 10, 2014 6:10 pm
To be brutally honest, I went for the flexible ones as it's less ballache to run them!
Being an occasional use car & not one that spends much time out in the elements, they should last me longer than I suspect they would in daily & nasty weather use. The stainless outer braiding should also offer a little more durability.
by bodgetastic » Mon Mar 10, 2014 11:03 pm
Please tell me you had more support than those axel stands or did you send those two lads under the car :lol:
by Robs-se » Tue Mar 11, 2014 3:56 am
Looks quite steady to me and the wheels are still on :lol: , but then I've seen some real horrors in jacking cars up
by DanSE4 » Tue Mar 11, 2014 9:40 am
Two axel stands under the front subframe & two under the rear crossmember works for me but yes, wheels stayed on! It did fall off the last stand when I was lowering it back down though (front offside) but it did it so slowly it was quite amusing to watch. :lol:
The two lads are mine & they are banned from so much as sticking a finger under the car when it's up in the air. They're bloody useful though for passing me spanners, wheel nuts etc. :twisted:
by craigyboy » Tue Mar 11, 2014 7:20 pm
Good job there mate :clap:
by GreyDJ » Tue Mar 11, 2014 8:01 pm
We used to call them apprentices :)
by DanSE4 » Wed Mar 12, 2014 10:57 am
GreyDJ wrote:We used to call them apprentices :)
Started training my eldest a few years back.......
He's a fair bit bigger now so time to begin on the youngest too I think! :)
by Teejay » Wed Mar 12, 2014 2:21 pm
It's Mr D with hair!!!!
