Over charging
Over charging
by Matt Bartlett » Tue Oct 15, 2013 7:20 pm
Finally, just over a year after switching my cally's engine off, I have got it running again!! I don't have the tools to lift the engine out but nearly everything else has been taken out, cleaned or replaced and put back in. This includes removing and stripping down the head, refurbishing the hydraulic lifters, new PAS and water pumps. Really pleased to here it running again but there is a small problem.... The alternator is charging at around 14.8-15v so the charge warning light is on all the while (it's a brand new battery). Also, the oil pressure gauge is reading off the scale.
So the question is a) is the alternator knackered (car was sat idle for 5 years before I bought it) or b) is the over charging and oil gauge reading linked?
Thanks for your help in advance and in the mean time I'll get on with looking at the brakes, suspension, transfer box, interior etc etc!! You all know the drill, never a quiet time when you own a Calibra lol!!
Re: Over charging
by v6 steve » Tue Oct 15, 2013 7:28 pm
i dont see anything wrong with that
Re: Over charging
by Matt Bartlett » Tue Oct 15, 2013 7:31 pm
Oh, ok. I was expecting somewhere around 13.5-14v? So why would the charging light be on and the oil gauge off the scale? Do you think the problems are linked or not?
Re: Over charging
by Allys Cally » Tue Oct 15, 2013 7:41 pm
oil gauge off the scale could be the sender units faulty or its got a loose wire
Re: Over charging
by Matt Bartlett » Tue Oct 15, 2013 7:53 pm
Am I right in thinking that the sender is somewhere near the oil filter?
Re: Over charging
by v6 steve » Tue Oct 15, 2013 7:56 pm
Matt Bartlett wrote:Oh, ok. I was expecting somewhere around 13.5-14v? So why would the charging light be on and the oil gauge off the scale? Do you think the problems are linked or not?
as ally says oil sender is naked or loose wire, as for the charging if it was only charging 13.5v and you put the lights ect on you would be taking more out the battery than its putting it back in
no its round the back under the alternator
Re: Over charging
by Fraz » Tue Oct 15, 2013 7:59 pm
Matt Bartlett wrote:Am I right in thinking that the sender is somewhere near the oil filter?
yes it is right under the alternator
Re: Over charging
by Matt Bartlett » Wed Oct 16, 2013 8:02 am
Thanks guys, I'll check the sender connections.
The reading I was getting was checked with a multimeter and the volt gauge above the ash tray says the same. The only light flickering is the actual charging(battery symbol) light itself. The interior light also flashes in time with it?
Re: Over charging
by Fraz » Wed Oct 16, 2013 8:31 am
you have not mixed the wires up for the oil sender and the thin wire for the alternator?
Re: Over charging
by Matt Bartlett » Wed Oct 16, 2013 8:39 am
Nope. I haven't disconnected either the alternator or oil sender....
Re: Over charging
by Fraz » Wed Oct 16, 2013 9:01 am
or if you can get an airline try blowing out the alternator...if its been sitting a while could have all sorts in there
Re: Over charging
by Robs-se » Wed Oct 16, 2013 8:17 pm
Think i would be inclined to look at a new alternator, especially after its been sitting so long, as said there could be alsorts going on internally like corrosion.
