Recent Calibra Purchases!
Re: Recent Calibra Purchases!
by rich30mex » Fri Sep 20, 2013 9:07 pm
v6 steve wrote:
KERR_SE9 wrote:Was just thinking that Fraz,a long shot I know but can anything be down to remove the paint?
i would have thought that they would have been keyed (scratched) so the paint would stay on, take the paint off it will F*****d
If it's a flat plastic surface it can be flattened back and repolished it Dunt look perfect but it's hard to tell if done correct
by EddeyDancer » Sat Sep 21, 2013 12:44 am
They both look to be in great condition...
I'm thinking of getting me a 2nd Calibra, kept as Standard, but used as a daily...
The Tungsten one, really has some nice features added onto it...
Very Envious...
by KERR_SE9 » Sat Sep 21, 2013 3:54 pm
Took some pics of the Xe cally today, do you guys reckon she's worth saving?
Plan is to put her in for an Mot and take it from there, Will be sold after some tlc:-
Jobs to do on Se9/Gold V6
Se9-Head Gasket change-Starting this today-Pics to follow
Gold V6:-
*Remove Towbar*
*Mirror glass on drivers side swapped over, has plastic on it* DONE
Before
AfterImage
Not much progress, but every little helps
*Rear lights back to standard*
*New discs/pads*
*New gaitors for handbrake/gearknob*
*New Mot*
by KERR_SE9 » Sat Sep 21, 2013 6:53 pm
Right, Started on the Se9 today, first off was a compression test, done front bank only, as pretty obvious it's f**ked!
Watch the video, that's a cold engine, not even been ran, just been turning it over!!!
Ouch!
What I can't understand is, if the compression from the combustion chamber is entering the cooling system, then why is the compression so high? Should it not be low?
by KERR_SE9 » Sat Sep 21, 2013 7:41 pm
Yeah,was water,as some came out relief valve on tester
by matty0785 » Sat Sep 21, 2013 8:12 pm
must be water in that cylinder and when cranking less air space and the water wont compress hence high reading
by KERR_SE9 » Sat Sep 21, 2013 9:56 pm
Didn't realise there was until, I released pressure from gauge, anyway head needs to come off!
So Iv'e started to strip it down (Excuse some of the boring pictures, It'll help me remember where it all goes)
Nice new waterpump, what a waste of time that was!
Fairly recent beltImage
Can anyone confirm, if this appears timed up right, before I undo it? And what's the extra notch for?
[URL=http://s728.photobucket.com/user/Kerr_Se9/media/SAM_0200_zpsa16fe76b.jpg.html]ImageImage[/URL]
Hungry now, and can feel GTA V calling me, So called it a night, hopefully have heads off tommorow
by KERR_SE9 » Sun Sep 22, 2013 7:25 pm
Towbar removed and sold,hope it does the job Fraz, looks much better, now for those shocking lights!
Can't believe that's a genuine Irmscher fill panel, painted
by KERR_SE9 » Sun Sep 22, 2013 7:30 pm
Continued on with the Se9:-
Got one head off, check the state of the gasket, the oil doesn't look to healthy either, lots of water in it, bit concerned now, wondering if I'd be better with an engine swap?
Water escaping everywhere
Nice watery oil!Image
Just the place, you want your antifreeze
Gasket well and truly fooked!
by v6 steve » Sun Sep 22, 2013 8:53 pm
youv went this far i would just be sticking on new gaskets
by KERR_SE9 » Fri Nov 22, 2013 9:31 pm
Right finally got my finger out, only been a month, Got the rear head off, and sent them to get skimmed, rear gasket whas just as bad, possibly worse than the front... thought V6 gaskets were not a common failure? So hope to have it up and running next week, So If anyway wants a nice clean standard Se9 with new gaskets and belts etc let me know!
Users browsing this forum: Google [Bot] and 17 guests
