Body Kit fitted
Re: Body Kit fitted
Excellent work there mate and plenty of great photos
very interesting
very interesting
Body Kit fitted
Fab thread there matey ! I'm real impressed with the workmanship you've put into the car . Keep ip the good work
Praise the Lowered !
Re: Body Kit fitted
looking good, keep the pictures coming
Re: Body Kit fitted
looking good mate what management are you using
Body Kit fitted
ECU and injectors are standard currently
I have a 3.0 ECU from an Omega that will go on but I want to combine it with a different inlet, injectors and remap
I'm thinking Sintra inlet and loom as I think it will fit under the bonnet but will have to fit a cone filter as the air filter sits the other side so will have to drop it down beside the gearbox
What was your V6 running, I'm sure someone told me it was hitting 240 brake over the weekend?
Re: Body Kit fitted
ye its about that last time it was on the rollers but its going throw a rebuild at the mo and hoping to break 250bhp
Re: Body Kit fitted
love the lime green hoses
Body Kit fitted
v6 steve wrote:ye its about that last time it was on the rollers but its going throw a rebuild at the mo and hoping to break 250bhp
Hmmm interesting, what's your set up?
I'm aiming for about the same - achievable and should still be reliable
Body Kit fitted
Decided it's time to put a kit back on.
So, as I'm also fitting 19" rims I had to deal with the issue of rubbing arches.
Got a pair of wings with rolled arches and went to Dan's (Calibra Halfway House) as he said he'd give me a hand.
Gail was on hand with the camera to chart the progress - bless
So first - bumper off
Pop the bonnet struts off and begin removing the wing bolts
There's always one f****r that you can't get to!
The nearside one was the easier of the two, offside one was a swear fest
This is in the footwell behind relay boxes, loom and padding
Front part of the skirt off to get to the one underneath
And two more on the side behind the bumper.
last bolt is on the bulkhead just next to the wing mirror assembly
Then it's off with the first wing.
Re: Body Kit fitted
keep them coming Tim
Re: Body Kit fitted
Body Kit fitted
Time for the other side:
Off comes the old one
Initially decided to try and retain the arch liners so trim age was required
New wing on
All appeared to fit with full lock both sides not fouling
Unfortunately as soon as I drove it the wheels started catching on the liners
So the 18"s went back on temporarily until the arch liners could be removed
Removed arch liners the next day, the voids will have to be stone guarded
So rolled arch wings fitted and 19"s on ready for the body shop
It turns out the rims were originally Shaza's!!!
I knew I'd get them eventually!
A few new parts to go on
New Rieger kit (front and rear aprons and side skirts)
A full set of upper and lower door seals and weather strips
New side repeaters
OK, here's the parts list for the body shop trip tomorrow
1 x upper o/s door seal
1 x lower o/s door seal
1 x lower n/s door seal
1 x upper n/s door seal
1 x o/s weather strip
1 x n/s weather strip
Rieger front and rear bumper lips inc. fitting kit
Rieger o/s and n/s side skirts
5 x black mesh sheets (1000mm x 400mm)
1 x rear bumper exhaust slot divider (mesh installation)
1 x Roof spoiler
10 x bump strips (1 x o/s front corner, 1 x n/s front corner, 1 x o/s rear corner, 1 x n/s rear corner, 1 x n/s side rear, 1 x n/s side middle, 1 x n/s side front, 1 x o/s side rear, 1 x o/s side middle, 1 x o/s side front)
1 x pack of side bump strip clips (spares)
1 x pack front and rear bump strip clips (spares)
1 x pair bonnet vents and frames
1 x front 'V' badge gel
1 x boot badge (spare)
1 x boot badge gel
1 x tow eye cover (cold air feed version) (spare)
1 x aerial base gasket (needs warming in hot water before installation)
New wing on
New side repeaters
1 x Roof spoiler
1 x boot badge gel
Body Kit fitted
Body shop progress
First the wheels got a refurb
Went with a polished lip but gun metal centres
Will live with them but might refurb again to silver
Now the body work starts!!!
The wings came off again to stone guard the voids and the inner side of the outer wings
A few dinks identified
Bonnet off ready for fitting the vents
Body Kit fitted
Work starts on attaching aprons and smoothing in
More dinks isolated
More dinks isolated
Users browsing this forum: Majestic-12 [Bot] and 20 guests
