Another year out the way
Passed its mot today
Only been advised about the head lights.Can they be converted
for the beam to face to the left?
Re: Another year out the way
on original headlights there is a small leaver to change Left to right ..do not know about aftermarket ones
its always a good day when they passsteve
Fraz wrote:on original headlights there is a small leaver to change Left to right ..do not know about aftermarket ones
i'm sure you can change them iirc, been that long since i had the angel eye lights so i'm not 100%
He said if I still have them on next year he
will fail it
will fail it
I would have failed it ...are they aftermarket ones you have ??
from the tester manual
Headlamps Reason for rejection
1.
A headlamp which does not conform to diagrams 1, 2 or 3 that has a beam image which is aimed so that it dazzles other road users.
2.
Projected beam image obviously incorrect, e.g. where the headlamp bulb is incorrectly fitted or the reflector is seriously corroded
1.
2.
They are Sonar and i'm gony try to adjust them
to suit
to suit
Are you an mot tester fraz?
KERR_SE9 wrote:Are you an mot tester fraz?
I was ...why you looking for a dodgy MOT ?
Ha fat chance, I get beasted for MOTs every time, with regards to you "failing" it, just wondered!
KERR_SE9 wrote:Ha fat chance, I get beasted for MOTs every time, with regards to you "failing" it, just wondered!
I said "I would have" past tense ...and I get on great with computers!!
Oh the encourgemt
or which ever way its spelt
or which ever way its spelt craig
encouragement for what
