Fuel pump relay
Re: Fuel pump relay
by Fraz » Sun Jan 13, 2013 12:11 pm
by pass the relay and run 12v to the pump .then see what happens...the fuel wont pump if the car don't start ...safety thing, so that way you can eliminate the fuel pump side of things
Re: Fuel pump relay
by v6 steve » Sun Jan 13, 2013 12:57 pm
PS
ill ref :lol:
Re: Fuel pump relay
by craigyboy » Sun Jan 13, 2013 5:31 pm
Fraz wrote:by pass the relay and run 12v to the pump .then see what happens...the fuel wont pump if the car don't start ...safety thing, so that way you can eliminate the fuel pump side of things
Ive bridged out the relays and can hear the pump running
I used to be able to hear a small buzzing noise under the
bonnet when the ignition was on.I wonder if this has anything
to do with it?
Re: Fuel pump relay
by v6 steve » Sun Jan 13, 2013 6:02 pm
isnt the buzzing from the engine bat the tps setting up ?
Re: Fuel pump relay
by Fraz » Sun Jan 13, 2013 6:09 pm
to do with it?
ut your still using the feeds at the relay by bridging them, I would try an direct 12V to the fuel pump feed and also another earth
other thing is it may well be the crank sensor...its a common problem with the ecotec
Re: Fuel pump relay
by craigyboy » Sun Jan 13, 2013 6:13 pm
Ive always heard the buzzing noise with just the ignition
on and theres no management light on :think:
Re: Fuel pump relay
by Fraz » Sun Jan 13, 2013 6:20 pm
craigyboy wrote:Ive always heard the buzzing noise with just the ignition
well if you have always herad it buzzing its nothing to do with that then
Re: Fuel pump relay
by craigyboy » Sun Jan 13, 2013 6:33 pm
I dont hear it anymore ,so I was thinking whatever it
was is now knackered and not sending a feed to the
pump?
Re: Fuel pump relay
by Callyman » Sun Jan 13, 2013 7:27 pm
craigyboy wrote:I was thinking whatever it
pump?
See below
Club Memberships
Club Memberships
Re: Fuel pump relay
by craigyboy » Sat Jan 19, 2013 9:41 pm
Thanks a lot for poping up today and finding the fault
It was the feed to the ecu plug that had corroded and broke off
the pin and it also didnt help that I had replaced the fuel pump
with one that was worse :whistle: .so we changed it back to the
original one and got the car started.So i'll put the rest of it back
together tomorrow.
Re: Fuel pump relay
by rich30mex » Sat Jan 19, 2013 9:58 pm
well do chaps
Events Coordinator
Events Coordinator
Re: Fuel pump relay
by Fraz » Sun Jan 20, 2013 12:15 pm
he don't use it very often though so is it left outside or in a nice warm garage ?? could just be condensation over the years
Re: Fuel pump relay
by v6 steve » Sun Jan 20, 2013 1:14 pm
Craig i did tell you you should always have a David in the tool box now i want him back lol
glad its all working
Re: Fuel pump relay
by craigyboy » Sun Jan 20, 2013 4:29 pm
It was definetly a weird one,one pin corroded out of 55 :think:
