no spark or fuel
no spark or fuel
by itsme1973 » Sun Nov 25, 2012 10:09 pm
need help have red top sat for a few years always started no problem. now wont start,fuel pump relay clicks when ignition switched on emlight is on even when turning over.tried another fuel pump relay from my other calibra 8 valve but still same.no spark either,have permanent live and switched live at ecu.power at coil but wont spark.thinking could be crank sensor.any ideas :-? cheers.
itsme1973
Re: no spark or fuel
by Fraz » Sun Nov 25, 2012 10:21 pm
best read the fault codes and post up ...short pins A&B of the plug up by the alarm horn
by v6 steve » Sun Nov 25, 2012 10:26 pm
sounds like the immobiliser has kicked in do as fraz has said it will flash up if it is
by itsme1973 » Sun Nov 25, 2012 10:39 pm
Fraz wrote:best read the fault codes and post up ...short pins A&B of the plug up by the alarm horn
have code reader from halfords checked it and all that came up was crank sensor, i think thats code 31.but thats because engine not cranking.i thought it could be something to do with motion sensors as even when not locked motion sensor lights up all the time even when doors aint locked.could this be something to do with imobilliser.cheers only stay down road at kelty.
itsme1973
by Fraz » Sun Nov 25, 2012 11:41 pm
try seeing if you get any alarm code by shorting pins A&H...what code reader do you have ??
I though the EML light had to flash while cranking for a immobiliser fault ..is it flashing or just on?
oh the code is flashed out on the ultrasonic led in the roof lining, passenger side
by itsme1973 » Mon Nov 26, 2012 9:09 pm
Its a gunsons fault finder obd1 that I have.engine management light stays on all time does not flash even when turning over.battery fully charged.I noticed the motion sensor light stays on when car is unlocked constantly on but when locked it flashes as normal.don't think light should be on constantly which makes Me think it could be immobiliser,but not sure if it cuts spark and fuel :|
itsme1973
by Fraz » Mon Nov 26, 2012 9:18 pm
I would try a ignition amplifier module ...mine sat for a long time and it blew, they are about £25
by itsme1973 » Mon Nov 26, 2012 10:06 pm
Fraz wrote:I would try a ignition amplifier module ...mine sat for a long time and it blew, they are about £25
Is their any way to test the amplifier with a multimeter or something.
itsme1973
by v6 steve » Mon Nov 26, 2012 10:17 pm
READ MY POST
by Fraz » Mon Nov 26, 2012 10:56 pm
the EML light has to flash while cranking for a immobiliser fault ..if its steady and no other faults come up, the amp would be my first suspect ...some motor factors have a tool to test them...I know WD factors can if your around that way
by itsme1973 » Sat Dec 08, 2012 5:58 pm
fixed the car now,it was crank sensor put one on and fired up straight away.cant beat an old vauxhall.cheers for all the info boys.
itsme1973
