Been a bit busy today
by Robs-se » Sun Aug 05, 2012 6:25 pm
Replaced a cv joint and both front discs. Just got the handbrake lever to do and then onto the paint work. 2 new tyres to go on the front as well
Re: Been a bit busy today
by v6 steve » Sun Aug 05, 2012 7:35 pm
:clap: :clap:
by Robs-se » Sun Aug 05, 2012 8:34 pm
Now i'm knackered, too old for this sh!t these days, and now the ABS light is coming on so the wheel will have to come off again
by Robs-se » Wed Aug 22, 2012 3:03 am
ABS light sorted once i changed the cv joint for the correct type and as i split the balljoint rubber with the splitter a new wishbone went on as well and b@gger me if the thread didn't strip on the vertical bolt :banging: :angry-screaming: . Tightened to the specific torque, and then started on the angle and suddenly the bolt just spins with the spanner now, and my wheel vibration has returned somewhat after getting it all sorted. Now i will have to cut a hole in the passenger side just like i did in the drivers side to put in an extra long nut and bolt. I hate this car now :axed:
Am now seriously thinking of getting rid and buying a Vectra VXR to replace it.
by Robs-se » Wed Aug 22, 2012 12:17 pm
I'm sure the love will return, once its sorted
by v6 steve » Wed Aug 22, 2012 8:12 pm
vectra vxr nice choice but im sure you would miss the cally
by Robs-se » Thu Aug 23, 2012 9:26 pm
ideally it would be Cally off the road for a while and get it sorted once and for all which i cant at the moment as i use it every day.Use the Vectra as a run around :)
by Dez » Fri Aug 24, 2012 8:07 pm
I know how you feel,it was one thing after another with my cally,i eventually gave up .Now im saving my pennies for a Vauxhall Monaro,gonna need a fuel tanker to drive the bugger :)
Dez
by Robs-se » Sat Aug 25, 2012 11:28 pm
Luckily the wishbone bolt was an easy fix :oops: . After jacking it up to remove the bolt ready to drive a punch up the hole (ooh eerrr) i thought i would see if it would tighten, spanner on bolt, turned it and it started to tighten. Then tried the torque wrench and f@ck me it tightened up. It then dawned on me what i did last time, when putting the big bar on it to go through the angles i looked at it from above and then undid it which made the bolt loose hence i thought the bolt/nut had stripped the thread :oops: :cry: .
Do i win numpty mechanic of the month??
by v6 steve » Sun Aug 26, 2012 8:34 am
:lol: never get me making that mistake :shifty:
by Robs-se » Sun Aug 26, 2012 12:09 pm
v6 steve wrote::lol: never get me making that mistake :shifty:
Or admitting to it :D
