overhaul begins
overhaul begins
Se6 rear subframe stipped off for re-furb and underfloor treatment
Re: overhaul begins
Lots of corrosion on that subframe.
Nice to see that I am not the only person that carries out most of the work in the fresh air.
- Gold Member
Re: overhaul begins
vec 160 wrote:Lots of corrosion on that subframe.
The sub frame will be getting rubbed down and painted in
the garage mate.Times like this I wish I had a bigger garage
to get alot more work done.
Re: overhaul begins
doing well there Craig, I gather new bushs etc will be fitted? you doing polly ones on that as well
Re: overhaul begins
you dont hang about do you. good work there ive got all that to come twice yet
Re: overhaul begins
Fraz wrote:doing well there Craig, I gather new bushs etc will be fitted? you doing polly ones on that as well
Yes Fraz, the only thing is they dont come too cheap.
Needs a bit of welding work done on it to
Re: overhaul begins
craigyboy wrote:Fraz wrote:doing well there Craig, I gather new bushs etc will be fitted? you doing polly ones on that as well
???? the subframe needs welding ?
are you going to paint it or powder coat it ?
Re: overhaul begins
Just goin to paint it Steve.If you look at the second pic
you can see the bit under the arch that needs welded
Re: overhaul begins
Good to see this is getting some deserved tlc
Re: overhaul begins
KERR_SE9 wrote:Good to see this is getting some deserved tlc
Already went through one wire brush attachment
for the grinder trying to clean up that subframe
Re: overhaul begins
craigyboy wrote:KERR_SE9 wrote:Good to see this is getting some deserved tlc
would you not be cheaper quicker and better finish getting it blasted
Re: overhaul begins
good work craig looking good
Re: overhaul begins
Yeah great thread, very interesting to see this progress
Re: overhaul begins
i'd have to agree with Steve you'll get a far better finish with it sandblasted mate, there's a place down our way that does it and their quite reasonable. if your interested let me know and i'll send you their details
