anbody got a duff battery theyre throwing out ?
Anybody got dodgy batteries around glasgow area they need disposed off, standard terminals for a high power battery, cally v6, fiat etc. promise ill take to recycling station when done with it
My alternators F++D and overcharging so will blow the good battery while its being driven to garage for a replacement unit.
Re: anbody got a duff battery theyre throwing out ?
charge the battery up fully, then take off the alternator belt and drive to the garage, obviously keeping everything electrical turned off.
Vxlgsi
Vxlgsi wrote:charge the battery up fully, then take off the alternator belt and drive to the garage, obviously keeping everything electrical turned off.
could still blow the ECU without some type of battery acting as a capacitor. A half done battery still has some capacitance (i use two in boot of van to smooth signal to my subs !) better than having nothing in the circuit. its 10 mile drive where im taking cally, , and i need to do some revving and slowing to get a years crud of the disks, as well as blow some crap out injectors while im on the road there
no you wont blow anything, leave the battery on and connected as nromall fully charged, disconnect the alternator, it will be just fine for 10 miles
Vxlgsi
Sorry i misread that as disconnect the battery when driving for some reason (blame it on the hot weather
)dont see why not just remove the alternator to battery live connector ?
no leave it all connected just take the alternator belt off, takes 2 mins
Vxlgsi
Vxlgsi wrote:no leave it all connected just take the alternator belt off, takes 2 mins
you cant do that on a v6 as it runs the water pump and power steering pump not much hassel with the steering pump but wouldnt want to drive with out the water pump
Ive got a dud battery if you want to try it mate
i stay in Baillieston
just take the signal wire off the alternator so it doesnt engage so alternator wont charge bump start the car and off you go it wont charge but run as normal
dont take the belt off it runs the water pump on the v6
matty0785 wrote:just take the signal wire off the alternator so it doesnt engage so alternator wont charge bump start the car and off you go it wont charge but run as normal
yeh i didnt quite fancy idea of running without a water pump ! Taking alt live of battery after starting engine, then taping it to somewhere with space or cables where it cant jump a spark, seems easiest solution.
craigyboy wrote:Ive got a dud battery if you want to try it mate
thanks craig. Think on reflection, disconnecting the alt live is wiser. A duff battery might have more chance of exploding than a regular as they demand more current.
hi
Thank you so much for the information.
It is really helpful.
2013 MERCEDES BENZ SL-CLASS
eva123
