been very very busy!
lower arms and subframe stripped!
poly bushes fitted and painted
all ready for re-fitting
all fitted
fit the wheels tomorrow bevy time
all fitted
Re: been very very busy!
good work but why does it look like you have painted the discs also?
- Club Member
Came up nice.
stevo turbo wrote:good work but why does it look like you have painted the discs also?
Just the centre parts Stevo,painted them with high temp paint
the rest is over spray which i'll rub off today.It is just to cover
up the surface rust
that crossed my mind as well
very nice Craig...lots of work going on
oh I made the mistake of painting the vents on the disc....even with high temp paint your going to find the inside of your wheels covered in wee spots of paint once you use them ..combination of heat and centrifugal force means the paint will get flung off through the disc vent holes
Thats it finished now,sounds alot better with the poly bushes
and new shocks fitted,it feels a more firm drive.No more clunking
sounds
sounds
Good Work Mate...
I'm not so sure about the Colour RED on any Calibra, but I hope it's giving You a better ride...
Cheers for the comments guys,i think it definetly
freshens it up a bit
At least the Corrosion situation, is being dealt with!!!
It's always good to know, what the condition of the Car is in...
Helps put your mind at ease!!!
Good work there mate. Looks much better
Front end all stripped again.putting back on lower arms
with ordinary rubber bushes,fitting new bilstein shocks
and apex springs.heres hopping the rides alot smoother
planning to post some pics tomorrow
