electric window module
by craigyboy » Wed Jan 25, 2012 5:58 pm
Does anyone know where this is located as the
windows don't appear to be working and the fuses
are all ok?
Re: electric window module
by Fraz » Wed Jan 25, 2012 6:05 pm
drivers kick plate big relay IIRC it grey in colour also does the locks as well
by craigyboy » Wed Jan 25, 2012 6:10 pm
Is that just at the right hand side of the pedals
Fraz and is it easy to get into?
by Fraz » Wed Jan 25, 2012 8:38 pm
yes and yes though you do need to take some of the screws out the plastic cill and there is one pop out lock tab at the top of the kick plate 9if still there) and then just pull it out
by v6 steve » Wed Jan 25, 2012 10:11 pm
Try tapping the motor at the same time as pressing the window button as some times they stick if water has got into it
by craigyboy » Wed Jan 25, 2012 11:52 pm
Cheers for that,i'll go and visit my donor car
on Friday and get some parts
by craigyboy » Sat Jan 28, 2012 10:46 pm
Tried the new module and Steves suggestion but no
luck,think it might be something to do with the toad
alarm.when i close the drivers door the buttons light
up faintly,but theres no power going to the motors
anyone any other suggestions please? :think:
by Fraz » Sun Jan 29, 2012 11:30 am
do the windows work with the switch??
if you think its your alarm, you would need to check that the toad alarm is sending a pulse signal to the window closure module
should be a wire that are joined on the wire from the window closure module, these will be the ones coming from your alram to the Brown/Black wire, see if its getting an earth pulse when you press your button
could aslo bare the wire a wee bit and supply an earth direct to it and your windows dhould go up
by craigyboy » Sun Jan 29, 2012 5:10 pm
The lights only come on faintly when the
doors are shut mate.I'll try what you said
Fraz
by craigyboy » Tue Jan 31, 2012 9:20 pm
does anyone know what the small printed circuit
beside the window switches is for?
by Fraz » Tue Jan 31, 2012 9:33 pm
picture would help ...only thing about there would be the airbag ECU but thats a metal box right at the back of the centre console. It may well be some after market thing that has been fitted ...or you have an older centre console that has the over ride switch for the windows
by craigyboy » Tue Jan 31, 2012 9:39 pm
Fraz its the small part about the size of
a matchbox on the window switch plate
just wondering if that could be causing
my window problem as theres a small
printed circuit inside it
by Fraz » Tue Jan 31, 2012 10:17 pm
that would be the window switch itself ..its part of the switch
by craigyboy » Fri Feb 03, 2012 11:24 pm
at last,got the windows fixed,it was the small
printed circuit board on the window switches :dance:
by rich30mex » Sat Feb 04, 2012 12:46 pm
Well done mate
