After Market Gear Knob
Guys got a new knob for xmas oh err, I removed the old one, but underneath is a plastic bit, didn't want to remove this as it looks like the reverse lever tension spring needs it, is that right or when removed is the spring kept in place by something else ?
Gaz
Gaz
LET the fun begin.
Re: After Market Gear Knob
I'm guessing the plastic thing left behind will pull off and the new knob can then be fitted to the shaft and the reverse spring will use the bottom of the new knob for tension ?? will going to give that ago at the weekend.
Gaz
Gaz
LET the fun begin.
it will depend on what gear knob you have got the one on mine still has the plastic lift
You have to get the proper one that Richbrook make
it has the wider gap at the bottom so the reverse lift
can come up
can come up
I can't change my knob
Mark1 wrote:I can't change my knob
Has it shrivelled up Mark?
callyman wrote:Mark1 wrote:I can't change my knob
I don't think so, it's black plastic!
Users browsing this forum: No registered users and 51 guests
