LED's in Dash with White Dials
Re: LED's in Dash with White Dials
Mark1 wrote:callyman wrote:Like this
http://www.ebay.co.uk/itm/VAUXHALL-CALI ... 062wt_1392
Copy Cat
Not me, I had them in my SE9, many years ago.
the ones i got where already fitted to the plastic frame
What type of LEDS do you fit in the switches and steering wheel
controls to brighten them up a bit?
its just as cheap to buy them done i got mine from astra on ebay ill go look for a link
i cant find her but theres loads of other people doing it
press on the link below Craig, this is an item that astra1973 is selling but you'll be able to contact her from this link. i sent all my switches to her last year to get done
http://www.ebay.co.uk/itm/ASTRA-MK4-G-Z ... 1c1f33b4bb
thats her cheers Ally, Craig tell her your from here and we sent you she'll sort you out and if she's not got what you need she's more than happ for you to send her your own switches, she was at billing seling them and vectra inlets you will have been at her stall no dout
Cheers Ally and Steve i'll give that a try
Thanks for the input Men...
I'm actually not at all captivated, by the chrome dial surrounds...
I'm just happy to fit the White LED's and check for any blown bulbs, as I suspect one or two!
I fitted the the White LED's in the dash last night...
1 - They do look better than the Original bulbs, but they're NOT as bright as I was hoping for!
2 - Also the light dimmer feature, NO longer works...
Is this because of the LED bulbs, or their colour?
Any helpful advice much appreciated...
Thanks...
Thanks...
your dimmer wont work now and it most just be the leds if there not as bright as you thought, but if they where very bright like my heater you cant see at night because of the glare so better not to bright
I was looking at 2 different types of T5 LED's today...
I noticed that one had a bigger LED eye, therefore makes more light...
Bugger, might have to pull it out again, cos I want them brighter...
At least it won't take so long, being it the 2nd time doing it...
I also put some LED's in the lower cluster section...
Mainly in the lights that get used most like, indicator, handbrake, oil, EML, high beam & 'S'
I used Red LED's in Handbrake and Oil lights, as the white light looked slightly faded...
Wish I has some yellow, blue and green LED's for the various sections!
I was hoping to do the lot in LED, but the Air Bag & ABS lights stayed..
I also put LED's in the Gear Selector, Cigarette Lighter and in Glove Box!
Looking Great!!!
Looking Great!!!
if you want bright go for the SMD type of LED ....much brighter they are
Ive recently put the blue leds behind the dials
and its not very bright.can anyone advise me on
the proper type to fit
cheers craig
cheers craig
