Remounting the alternator
by v6 steve » Fri Oct 07, 2011 10:06 pm
has anyone ever or has anyone ever thought about putting an other alternator on to a v6 in place of the air con pump, i cant see it being to much of a hassle just need a bracket made up so the belt still fits,
Re: Remounting the alternator
by Fraz » Fri Oct 07, 2011 10:23 pm
What you want 2 alternators for
Sent from my HTC Wildfire S A510e
by v6 steve » Fri Oct 07, 2011 10:59 pm
could i not put a bigger pully on to stop the slipping or would that cause it too fast and F*** up, the reason i need to do somthing is the install takes more power out than i can put back into the batterys when its at shows and only on idle
by v6 steve » Fri Oct 07, 2011 11:57 pm
1 hour or so depends on what all is turnned on 3 x amps, ps3, 19" tv 2x7" tv smoke machine 8x speakers and sub + all the leds
by Robs-se » Sat Oct 08, 2011 1:31 am
Its a generator you want to install :)
by big_gordy » Sat Oct 08, 2011 12:31 pm
get a split charger and put another battery in and make sure its a gel on so if it runs down completly flat it wont damage it
upgrade the alt and upgrade the batery terminals and wire... :ugeek:
http://www.driverstechnology.co.uk/car-batteries.htm
by v6 steve » Sat Oct 08, 2011 12:49 pm
big_gordy wrote:get a split charger and put another battery in and make sure its a gel (i think im sure correct me if im wrong !) on so if it runs down completly flat it wont damage it
its got a marine battery in the back all ready with a split charger and an uprated 120watt alternator, it could do with a larger gauge wire for the split charger but there still wont be enough power from one alternator, remember when at shows its only on idle
by tazz666 » Sat Oct 08, 2011 8:51 pm
in the early 90,s on big installs, they used to use 2,to 3 + alternators on there installs,so maybe getting in touch with some one from a company like fusion,vibe or someone who build installs
by rich30mex » Sun Oct 09, 2011 2:35 pm
try paul at source sound sheffield he nows his stuf im sure he will help
http://sourcecars.com/
remember hes the 1 who was going to us a discount but someone couldent be 4rsed to get intouch with him :whistle:
by v6 steve » Sun Oct 09, 2011 2:46 pm
i think i know what it do i just wanted to know if any one els has done it
