ABS help
ABS help
by Robs-se » Mon Sep 26, 2011 6:51 pm
ABS light has started coming on and staying on and is giving codes 39 and 41 LH Front speed sensor.
Was replacing the complete tie tie rod bar that side the other day and dont remember knocking any wires,
Anyone any other suggestions until i can get the wheel off. I'm at work at the moment and cant do it just now
Re: ABS help
by v6 steve » Mon Sep 26, 2011 6:53 pm
hows your rings ?
Re: ABS help
by Robs-se » Mon Sep 26, 2011 6:59 pm
LH one looks ok and the right hand is new as i did the CV joint a few months back
Re: ABS help
by Robs-se » Tue Sep 27, 2011 8:34 am
Will do when i get the wheel back off tomorrow, never know it might be very obvious what it is then :lol:
Re: ABS help
by Robs-se » Sun Oct 02, 2011 11:35 pm
Connections in wheel arch are ok, the teeth are somewhat rusty but not missing and now the abs light only comes on when doing a left turn on full lock. Apart from replacing the CV joint i'm a bit stuck. Oh and tracking is out hence replacing track rods as they are siezed and caused a bald patch on an otherwise perfect tyre :( . Any more suggestions
Re: ABS help
by Fraz » Mon Oct 03, 2011 1:07 am
if it only brining the light on with full lock, sounds like the connection is coming loose only on full lock
have you checked how tight the wires get on full lock? try disconnecting the wires then then a wee squirt with WD40 and re join
Re: ABS help
by Robs-se » Mon Oct 03, 2011 3:20 pm
Comes on and stays on, will recheck the connections and give the teeth another clean up
Re: ABS help
by Robs-se » Sat Oct 15, 2011 11:08 pm
Amazing what a bit of vaseline does on your connectors
Re: ABS help
by Caly2c » Thu Dec 15, 2011 6:35 am
Hi, i am having a similar problem with the light staying on. I did the paper clip test with no codes. Tried a snap on scan tool, but it couldnt read or communicate with the ABS module. We tested the car on the hoist spinning each wheel and hitting the brakes and all the sensors appear to be working and the module could be heard doing its thing. On the road in the wet the LHF only locks up. Could it be a faulty ring that is causing the problem?
thanks
Ben
Caly2c
Re: ABS help
by Robs-se » Thu Dec 15, 2011 8:28 pm
Check the connector, i cleaned mine out with a squirt of wd40 and a cotton bud, then put a smidging of vaseline on the conectors and it was then working fine. I also gave the ring a a bit of a clean up as well
Re: ABS help
by Caly2c » Fri Dec 16, 2011 2:19 am
Hi Rob, thanks for the reply. Ill be draging it out for the summer over christmas. ill get into work again and give it a go. Ill let you know the results :)
Caly2c
