Im new and just bought a cally turb
Re: Im new and just bought a cally turb
its an early type so will have headlight washres
but if you have the under wing one there would be no need for the upper wing one, has anyone else got both ? my v6 has under wing and the turbo upper wing type
one is for the front/rear washers....the other is just for the headlight washers, only the early one with the headlight washers had both fitted
Fraz wrote:its an early type so will have headlight washres
Mmmm i might fit some to mine.
Now, where to find some washers.......
Those alloys came up very clean, did you use the bath? lol
no i used the stuff i got for cleaning my supermoto and a kitchen scrub sponge type thing.
flash floor cleaner does the same thing!
Vxlgsi
Vxlgsi, do you have the part number by chance for the seal you replaced on the gear selector? When I spoke to vauxhall about replacing mine to sort out the slack in mine they had no idea what I was on about. Loving the standard turbo by the way.
I dont sorry, took the guy about 20 seconds to find it on epc so i cant see why it was a problem, failing that it takes seconds to remove it from the car. you could literally pull up at vauxhall and remove it and walk in with the gearstick in yor hand and show them the bush!
Vxlgsi
Vxlgsi wrote:I dont sorry, took the guy about 20 seconds to find it on epc so i cant see why it was a problem, failing that it takes seconds to remove it from the car. you could literally pull up at vauxhall and remove it and walk in with the gearstick in yor hand and show them the bush!
No worries chap, thank you anyway.
So due to lack of free time ive shipped the cally off to a mate to get some work done.
Uploaded with ImageShack.us
I opted to trailer it over as the water pump sounded abit fecked so i thought its best not to risk a 40 min drive. I soon found id been quite lucky, My friend rang and said it was good I hadnt driven it as the cambelt was so loose id be lucky to get a mile down the road. He was quite shocked when i told him it took 2.5 hours to drive it home and i streached its legs afew times.
Vxlgsi
washed ready for stonechip repair and some super resin action.
so i spent a little time tidying up the engine bay, bit of a clean here and there and a new header tank, not exactly inpressive but im happy with it as its no show car.
Would really like a battery jacket and a new washerbottle now though finding one wont be easy.
Cant get the awfull staining off the suspension turrets which is annoying!
Vxlgsi
pappasmurf wrote:Vxlgsi, do you have the part number by chance for the seal you replaced on the gear selector? When I spoke to vauxhall about replacing mine to sort out the slack in mine they had no idea what I was on about. Loving the standard turbo by the way.
its 90250175
Fraz wrote:pappasmurf wrote:Vxlgsi, do you have the part number by chance for the seal you replaced on the gear selector? When I spoke to vauxhall about replacing mine to sort out the slack in mine they had no idea what I was on about. Loving the standard turbo by the way.
its 90250175
Cheers for that Fraz
Calibra has been uncovered for another summer, first job was to swap out the rear bushes, these are what i took out....
Nothing wrong with them at all so that was a waste of money oh well.
Then I went to fit my new CD300 to find id been screwed over by a guy on PNG and it doesnt work
so tape player is going back in once ive fitted a new radio signal amplifier.
Just need to find some wheel nut covers and drop the fuel tank as the sender is playing up anything over half a tank and it says its empty... mmm really looking forward to that!
Vxlgsi
Users browsing this forum: No registered users and 91 guests
