found out why!
found out why!
by big_gordy » Sat Apr 23, 2011 2:15 am
found out why my car was soaking wet in the passengers side footwell and really was abvious !
Re: found out why!
will need to investigate more just to make sure!
Re: found out why!
by big_gordy » Sat Apr 23, 2011 2:17 am
replaced rubber!
didnt take to long either to do it!
Re: found out why!
by Mark1 » Sat Apr 23, 2011 6:32 am
I'd get the bird shjt offf before it marks the paint.
Re: found out why!
by v6 steve » Sat Apr 23, 2011 9:47 am
are you sure that's where it was coming in as any water running down the window should run out the bottom of the door, and its the inside bit of the rubber that seals the window not the bit in pic 3 that is all cracked, good job tho looks alot better with it replaced :clap:
Re: found out why!
by big_gordy » Sat Apr 23, 2011 9:47 am
it is off mark lol
Re: found out why!
by big_gordy » Sat Apr 23, 2011 9:50 am
v6 steve wrote:are you sure that's where it was coming in as any water running down the window should run out the bottom of the door, and its the inside bit of the rubber that seals the window not the bit in pic 3 that is all cracked, good job tho looks alot better with it replaced :clap:
you are right steve im not sure so need to get the car soaked and see if it comes back in and from where!
one of the many jobs i need to do before i start going tho the shows! :alright:
Re: found out why!
by v6 steve » Sat Apr 23, 2011 9:54 am
try the bottom left hand corner of the windscreen that's where Steve's was leaking the, it had a new windscreen put in and it hadnt been glued right, also lift the carpet and see if there's and holes at the left hand footwell, it could just be condensation from the winter we had
Re: found out why!
by Fraz » Sat Apr 23, 2011 12:58 pm
but you knew about that seal way back in October
viewtopic.php?f=21&t=45432&hilit=+window
Re: found out why!
by big_gordy » Sat Apr 23, 2011 1:32 pm
lol i know fras but never though it would have let in as much water as it did! :doh: could be cause the painter hasnt tightened up summit as the wings look off too :bang:
Re: found out why!
by Robs-se » Sun Apr 24, 2011 8:34 pm
Try this drain hole under the scuttle panel it maybe from here
Re: found out why!
by big_gordy » Mon Apr 25, 2011 3:08 pm
haa cheers rob ill have a look at that!! :clap: :ugeek:
Re: found out why!
by MadOnVaux! » Tue Apr 26, 2011 4:45 pm
Sorry to hijack this, but the drain hole under the scuttle, how does that let water in the inside? I thought it should drain away outside the body, down the inner wing?
Just that my drivers side gets very wet, but under the carpet....my 1st thoughts were the seal on the blower cowl letting water in?
Re: found out why!
by Fraz » Tue Apr 26, 2011 5:38 pm
the drains (there is also the elephant trunk thingy) if they are blcoked will mean the water wont drain away, and then it will be able to get over the small lip around the heater blower and leak inside
Re: found out why!
by MadOnVaux! » Wed Apr 27, 2011 3:38 pm
Fraz wrote:the drains (there is also the elephant trunk thingy) if they are blocked will mean the water wont drain away, and then it will be able to get over the small lip around the heater blower and leak inside
Cheers....but how do you know if the holes at the side of the scuttles (as in the pic) are blocked?, or is it just that if the actual hole is blocked then its blocked?
The seal can also go on the heater blower lip too, i had that go on one of my old cavs!
Users browsing this forum: No registered users and 125 guests
