Anyone use iridium plugs?
Are they as good as the advertising bumf or is it wiser to stick to the ngk jobbies and save the extra cash ?
v6bob
Re: Anyone use iridium plugs?
iv got them in ma turbo but i cant see the advantage of putting them in the v6
Stick with cheap ones and change them at regular service interals
I just use standard one's in mine.
Ill stick with the standard ones then, just thought id ask in case anyone recommended them
v6bob
yep standards as well but i think this year i may have to replace the ht leads as they are 3 years old.
Baz my leads are 15 years old. You don't change leads unless you get a problem.
you used to change leads same time as the plugs, but that was the old copper core ones ...stopped them as they caused interference with all sorts of things
no i think the leads will need to be changed as the car doesnt seem as good , i know ages i said to you guys that i would be changing them but back then i didnt know how to remove the rear bank ones and until you showed me that day andy ive removed the inlet manifold so many times now lol.
Make sure you get OE leads then, anything cheap wont last and actually give more resistance.
If you want Magnecors Baz, (and tbh they are the only ones id have except originals) they are a few quid cheaper here
http://www.europerformance.co.uk/pages/ ... =555570184
no they are way out of my price range , i will stick to oe ones from autovaux tbh
Baz how much are the autovaux set?
