Big Brakes
Big Brakes
by v6 steve » Thu Jan 13, 2011 9:01 pm
ok guys a wee brain teaser for you
im putting big 4 pot callipers on the turbo from an other car (not goig to spend £1200 on a LMF kit) what ones do you think will fit without too much work, or what cars have you taken bits from to make your own kit
Re: Big Brakes
by Callyman » Thu Jan 13, 2011 10:01 pm
mmm, i will ask my vaux mate Sheldon when i see him Steve.
Re: Big Brakes
by v6 steve » Thu Jan 13, 2011 10:10 pm
iv started a set today but not sure if there is an easer way or if someone has done it already and i could get sizes from them
Re: Big Brakes
by v6 steve » Sun Jan 16, 2011 10:20 pm
has any one fitted Fait coupe turbo callipers ? i got a set and had a wee dry fitting on saterday and by my mesurments i will need a 19" or 20" wheel and a 350mm disc to make it all work,
Re: Big Brakes
by Robs-se » Mon Jan 17, 2011 2:16 pm
I have Billet4 4 pots on mine with a 285mm disc on a 4 stud pattern and 17inch wheels are a snug fit :D
Re: Big Brakes
by matty0785 » Mon Jan 17, 2011 5:38 pm
fiat 20v turbo brembo's will go under 16's
OR
http://www.astraownersclub.com/vb/showt ... p?t=291315
Re: Big Brakes
by v6 steve » Mon Jan 17, 2011 6:00 pm
your link dosnt work
Re: Big Brakes
by matty0785 » Mon Jan 17, 2011 6:14 pm
you will need to register and search for brembo 4 pot calipers and brackets for sale by a guy called montyfox
Re: Big Brakes
by v6 steve » Mon Jan 17, 2011 7:14 pm
its working now
Re: Big Brakes
by superfox233 » Mon Jan 17, 2011 7:16 pm
ooooo!! What about audi brakes?? Or vx220 ap brakes??
superfox233
Re: Big Brakes
by v6 steve » Mon Jan 17, 2011 7:32 pm
which audi ? and do you know they fit or is it just a suggestion
Re: Big Brakes
by tiff_lee » Fri Feb 04, 2011 12:56 am
What sort of power level is the standard turbo brakes good for? as much as I'd like to have nice gucci 4 pots I don't fancy splashing out if there is no real need.
tiff_lee
Re: Big Brakes
by v6 steve » Fri Feb 04, 2011 9:41 am
my brakes are good and stop me from silly speeds but heat up after time and then fad, on the Highland tour last year i had smoke belching out from the a couple of times after doing the private road stages :whistle: thats why im wanting to upgrade mine if not a good set of pads and disc would be fine for most turbos
Re: Big Brakes
by tiff_lee » Sat Feb 05, 2011 11:52 am
Smoke, blimey you must of been having some fun ;)
tiff_lee
