calling all LPG converted calibras
i am the only one on here that has an lpg calibra v6?
if not is anyone else had any problems with it or faulse fault code readings?
Re: calling all LPG converted calibras
Your the only one, so best off talking to yourself
RobbieV wrote:Your the only one, so best off talking to yourself
I would have thought that running LPG all the time would casue the lambda sensor to give false readings ....do you ever run it on petrol for a day or so ??
i thought you where only to put on lpg when on long steady trips not use it all the time
According to websites, you need to use injector cleaner in the fuel and use the treated petrol until the engine is warmed up. (sort of hidden cost if you like)......Then it's safe to switch over to lpg...
but i'm with Fraz... I'd be tempted to use petrol every week or so...
superfox233
im with everyone on this Gordy i would be using the petrol more than the lpg,
been using petrol most of the time then switch to lpg on motorways!
was just a question i thought i would ask as im still getting code 13 and 38
probably wont go away then
awww im unique then for LPG v6 hehhehehehe
poor gordy lol
so whats the consumption that your LPG does , dont worry im not thinking of converting
55mpg
i didnt think that you got better MPG with LPG i thought it was just cheaper so you got more miles per £
tazz666 wrote:aye you can get 55mph if you drive like a granny
Why would you have a 150mph 3 door coupe and drive it like a granny
