Calibra BC- Doesn't fully work
I've installed BC in my car ( there was a watch before ) but it doesn't fully work as expected. see video below. The LED doesn't work either (it's operative though).
please help
See the video
http://www.youtube.com/watch?v=nsXNXh9rSZ4
please help
See the video
Chipa
Re: Calibra BC- Doesn't fully work
Did you get the right chip for the car with it?
He means the computer chip in the Fuel comp, is it calibrated for your engine ?
have you got a Mechanical counter or by abs ??
did you roll with?
did you roll with?
the range function will not work with the LCD dash fitted ...that is why you have a "F" displayed for fault
RobbieV,
I do not know. I only buy and BC panel and i connect it..
mic43,
Abs - what is in the middle?
Fraz,
How can I do? You told me?
mic43,
Fraz,
Chipa
The fuel comp has different chips for different engines.
on the back of the comp you'll see a white/yellow plastic chip that has to match the engine in your car or it has to be reprogrammed with a tech 1
press and hold the two buttons for the trip computer ...the ones on center console ...turn igntion on and get the numbers that come up on BC ...will tell you the codes for the BC chip
v6 steve,
do you mean this?
Fraz,
I did that, and text on display was 8544. What should I do next?
check out this vid
http://www.youtube.com/watch?v=1irPThRcLuw
How do I find out whether bc chip code matches my engine or not?
do you mean this?
Fraz,
check out this vid
Chipa
yes that is the chip in the BC
and your code 36 is for 20NE/SEJ, 20SE/SEJ, C20NE/SE Motronic ML4.1
so your readings wil be well out
My engine is C20ne. So, my engine should communicate with BC just fine?
Any ideas what to do next?
Chipa
but dont the Calibra C20NE use Motronic M1.5???? But I do not know what your trying to fix ....everything seems to work as it should apart from the range function ....and that will not work with the LCD dash fitted, well we cant get it to work over here anyway
oh and looks like your dash needs new blubs
should be bright like mine is
i'll post another video to illustrate it better
..and which bulbs do you recomend? can i buy them on ebay or elsewhere? can you post he link?
Chipa
