rear brake size...97 v6(se9)
as title really
90379910 its the two 9s in the number i cant quite make out.this is a gm part number from my discs.just looking online but they seem to list various rear sizes in the 95-98 category????
wheres Fraz lol..
some list 270 280 etc...they look to be 270 mm hard to measure whilst in situ.
wheres Fraz lol..
k1nty
Re: rear brake size...97 v6(se9)
270mm they are.
cheers Robbie,makes you wonder where they get the info..
ill price up now,
ill price up now,
k1nty
You Called ???
and that part number you posted is a HARNESS, ASSY., INSTRUMENT PANEL, RHD
Fraz wrote:You Called ???
thats the number stamped in the disc...its the 2 9s in the middle im not clear on...cheers anyway...looks like the 70s on rear.
k1nty
According to an old Trade Club book (2003!) I have the part no for the rear disc/drum is 90442651 for both Turbo and V6 and this is still the number listed today on online Trade Club. Retail is an eye watering £107 plus VAT.
Cavalier CDi 96 Grey
Cavalier SRi 93 Satin Red
Cavalier Mk2 CD130 86 White
if i could post my pic i would...it deffo says gm 9037_ _10
could be 55 in middle.might be eye watering but vauxhall was then good quality.
k1nty
Agree with the quality. If you can get it Trade Club it is £68!
so does the turbo come up as same number for a 96 back n front???
k1nty
Seems to, the front discs are 90442513 for both Turbo and V6 any age. The callipers and hence pads are different on pre and post 96 cars.
Just had a thought, these numbers I quote are for a pair. A single disc will have a different number.
damn guys....
1) front brakes where 284mm diameter (other dimensions differ also) until ~95. afterwards 288mm - the same were used on vectra b.
2) rear brakes differ also. their depth differs in center (sorry - my english sucks sometimes) - they changed aswell in that ~95. the depth - hub goes "into" brake disc differs. earlier ones go deeper.
you can use 280mm rear brake discs from omega b, but you need brake calipers also and brake pads too. brake caliper from omega was used 2x40mm (Calibra ones are 2x33mm or 2x35mm)
p.s. I used to have "old" brakes - changed front to 288, rear to 280mm. as I was changing also wheel bearings it wasnt problem. front hub needed less diameter. rear hub needs to be put deeper into bearing. i put it there on about 8 or 9mm (I used brembo catalogue for dimensions and calculated difference).
U_V6
Does the use by GM of one part number for all years front discs mean the larger disc can be used with the 'smaller' disc's callipers?
calipers are different. 284mm discs have 54mm piston calipers, 288mm discs have 57mm piston calipers. and brake pads also are different. what can or cannot be swaped - I don't know.
U_V6
The top picture from a box is the part number for a pair, the number stamped on the disc must be the number of a single disc.
