brake bleeding order
by cally8valver » Tue Jun 08, 2010 6:07 pm
need help before i replace all my fluid in my brake system as need to change abs pump in which order do i need to blee the brakes in i will be doing it myself with a easibleed kit it is a se6 8valver cheers in advance guys
cally8valver
Re: brake bleeding order
by vinny_69 » Tue Jun 08, 2010 6:09 pm
iirc start on the rears first :D
by GreyDJ » Tue Jun 08, 2010 6:17 pm
Cavalier CDi 96 Grey
Cavalier SRi 93 Satin Red
Cavalier Mk2 CD130 86 White
by cally8valver » Tue Jun 08, 2010 6:22 pm
cheers guys
cally8valver
by big_gordy » Tue Jun 08, 2010 10:52 pm
but is it not the furthest away 1 1st so it would be the passengers side back then drivers side then the passengers front then drivers front :ugeek:
do u not have a haynes manual?? if not pm me :whistle:
by GreyDJ » Wed Jun 09, 2010 1:06 am
big_gordy wrote:but is it not the furthest away 1 1st so it would be the passengers side back then drivers side then the passengers front then drivers front :ugeek:
I think that was true in single or twin pipe systems to avoid contamination. Now that all the pipes go back to either the master cylinder or the ABS unit it is not so important.
by Fraz » Wed Jun 09, 2010 1:48 pm
should still be the furthest away from the master cylinder as that one will most likely have the most air in the system, and since its a duel system then also bleed the diagonal opposite of that one as that will be on the same circuit ....and if you can use a pressure bleeder...its much easier and also let you see any leaks
by Fraz » Wed Jun 09, 2010 1:52 pm
Gordon will you stop asking people to pm you to get a copy of the Haynes manual ....its rather obvious what your intention is ..IE you will send them one, especially as you then come on with "they have one now" ...use the pm system and keep it off the open forum please ...I think you know why :axed:
Users browsing this forum: Bing [Bot] and 12 guests
